06-15-2017, 03:12 PM | #1 |
Lost my ignition keys!
Ok somehow I lost the keys to my 56 mercury, my question is, is there any way I can get the lock cylinder out without the key or should I just buy a whole new switch?
Thanks Ryan Sent from my iPhone using Tapatalk |
06-15-2017, 04:06 PM | #2 |
Re: Lost my ignition keys!
you may be able to remove the ignition switch depending on your ability.I do not think it will help as I do not think there is a number on switch to have a new key cut.do not forget to disconnect the battery to avoid shorting a wire or two while removing.
06-15-2017, 07:06 PM | #3 |
I have the switch hanging under there now. I just didn't want to disconnect the wiring till I have a new switch if I had to get one
06-15-2017, 07:12 PM | #4 |
if you can get the cylinder out a locksmith can make you a key or just take the whole swtich
06-15-2017, 07:14 PM | #5 |
Most lock smiths can cut a key to your switch. If you are in a metropolitan area call around and ask if they can make you a key. Disconnect the wires and take it to him.
EDIT sorry Frank. I was slow typing. |
06-18-2017, 08:41 PM | #6 |
06-18-2017, 08:53 PM | #7 | |
Charlie Stephens |
06-18-2017, 09:42 PM | #8 |
Sorry, duplicate post.
Charlie Stephens Last edited by Charlie Stephens; 06-18-2017 at 09:49 PM. |
06-19-2017, 11:19 PM | #9 |
You may be able to remove the door lock cylinder and it may have a code number on it which will match the ignition (if original). If it does, many locksmiths can still cut to that code. If not, replacement ignition cylinder is your best bet.
Obsolete Jim |
06-21-2017, 07:00 PM | #10 |
And, if you need the Ignition Switch // and / or Ignition Tumbler -- Brand New !!! -- I have both of them -- in Motorcraft and N.O.S. U.S.A. made
"aftermarket"..... (different price, of course....) You are welcome to call me, if you need...... Craig -- 516 - 485 - 1935 .... Long Island, New York.... Good Luck!!!! |
