Old 01-11-2020, 01:43 PM   #1
Brentwood Bob
Default Throttle shaft brass plug for zenith carbs
Guess this is not available.
Anyone know where I can purchase these?
Renners had one.
Shaped like a welsh plug.
Brentwood Bob is offline   Reply With Quote
Old 01-11-2020, 02:08 PM   #2
Brentwood Bob
Default Re: Throttle shaft brass plug for zenith carbs
Sacramento vintage describes the part as: throttle shaft end plug.
I saw it listed in a United Kingdom supplier online catalog.
Old 01-11-2020, 02:41 PM   #3
Synchro909
Synchro909's Avatar
I seal that by putting some oil on the end of the shaft and some epoxy putty over it. The oil prevents the epoxy sticking to the shaft. It is on the hidden side of the carby and my car is a driver so that's fine by me.
Old 01-11-2020, 03:52 PM   #4
Gary Karr
Gary Karr's Avatar
By chance does A&L have them? I bought some a couple of years ago. I just don't remember who I got them from.
Gary Karr is offline   Reply With Quote
Old 01-11-2020, 05:51 PM   #5
ursus
Now there is a bit of genius! I never would have thought of that.
Old 01-11-2020, 06:20 PM   #6
Bob-A
Bob-A's Avatar
I think Bratton's carries them??
Bob-A
Bob-A is offline   Reply With Quote
Old 01-11-2020, 06:48 PM   #7
SteveB31
SteveB31's Avatar
Nobody has made them for 6 years.
SteveB31 is offline   Reply With Quote
Old 01-11-2020, 09:41 PM   #8
Benson
Benson's Avatar
1. I use a sheet of flat plastic ... the kind that those plastic "blister" packages that are almost indestructible are made of.
2. Punch a hole with one of those hand paper punches that punches one hole and save the "hole".
click link for photo
https://www.carlmfg.com/medium-duty-single-hole-punch/
3. Put the "hole" inside throttle shaft bushing area.("Hole" keeps shaft from getting stuck to JB Weld)
4. Then as mentioned above use J B Weld to fill hole even with the casting.
5. Powder coating or painting does not affect J B Weld.
Old 01-11-2020, 10:29 PM   #9
Brentwood Bob
Looks like I am SOOL.
Old 01-12-2020, 03:04 PM   #10
Brentwood Bob
Elusive. Maybe offshore? New Zealand?
Old 01-12-2020, 10:53 PM   #11
Gary WA
Gary WA's Avatar
I have used a brass shell casing,file the rim,and insert with small amount jb weld. I think it was a 22 or 17mm casing? not sure on size, looked nice and authentic. Have to look in my files as to the exact size of shell.
www.whidbeymodelaclub.com
Old 01-13-2020, 01:11 AM   #12
Brentwood Bob
That crossed my mind. A rim fire cartridge?
Thanks for the idea.
Old 01-13-2020, 11:22 AM   #13
Gary WA
Gary WA's Avatar
yes
Old 01-13-2020, 11:39 PM   #14
redmodelt
redmodelt's Avatar
or get some of the brass tubing that is sold in the hobby display at most hardware/crafts stores cut a piece off and solder on a disk. If it fits a little lose, use some JB Weld.
Old 01-14-2020, 12:35 AM   #15
Penthode
Penthode's Avatar
I cut a piece of oversized brass rod and used my lathe to make it fit.
Penthode is offline   Reply With Quote
Old 01-14-2020, 12:49 AM   #16
Brentwood Bob
No lathe here, but I like the shell casing idea, or the tubing.
Old 01-14-2020, 10:41 AM   #17
Bob-A
Bob-A's Avatar
I contacted Bratton's about the brass plugs. They said the individual who was making them passed away and the punch/dies used to make them were lost. Not enough demand to make anymore tools needed to create the plugs.
Bob-A
Old 01-14-2020, 11:51 AM   #18
Brentwood Bob
Not good news.
Old 01-15-2020, 01:19 PM   #19
Gary WA
Gary WA's Avatar
$.59Welcome to Mike's Carburetor Parts - Your Number 1 Carburetor Parts Store
Old 01-15-2020, 01:50 PM   #20
Brentwood Bob
Thanks, sent a pm.
