Old 09-11-2019, 08:15 PM   #1
swoopNZ
MEMBER EMERITUS
Default 40 pickup seat
Anyone have some pictures of the wooden base under a 40 1/2 ton pickup seat.
Mine is plywood but I'm not sure if was originally like that.
Many thanks in advance.
Swoop.NZ.
New Zealand.
swoopNZ is offline   Reply With Quote
Old 09-12-2019, 05:48 AM   #2
skidmarks
skidmarks's Avatar
Default Re: 40 pickup seat
Plywood with an pattern of holes to let the air escape when you sit down so the seams done split.
Sorry no picture.
That's what my 40 has and I had a orginal 38 that was the same way
skidmarks is offline   Reply With Quote
Old 09-12-2019, 08:40 AM   #3
TJ
TJ's Avatar
Definitely plywood and I think it is 5/8" plywood.There's also holes on the front edge (two on each side) that drop over the pins on the metal riser edge. They hold the bottom in place and also allow for some adjustment forward and back of the bottom cushion
Old 09-12-2019, 08:48 AM   #4
Kube
Kube's Avatar
Here ya go Chris...3/4" plywood.
Old 09-12-2019, 04:28 PM   #5
swoopNZ
MEMBER EMERITUS
Thanks for that. Looks like mine is original.
