Old 04-04-2012, 05:51 PM   #1
Contenderizer
Contenderizer's Avatar
Default Newbe Questions
1) My 29 Pick-up has a windshield that opens from the bottom (hinged at the top). Unfortunately, there is no mechanism to hold the windshield in the open position. Photos I have seen suggest that originally there was something on the side of the windshield that might have been for that purpose. Am I correct? Where can I find same? Any other suggestions? I live in Florida and need my air conditioning.
2) Does anyone make a reproduction tool kit?
As usual, thanks
Contenderizer is offline   Reply With Quote
Old 04-04-2012, 06:22 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Newbe Questions
Hi Contenderizer and welcome to the club. Yes there are two arms (one on each side) with screw nuts that will hold the windshield open. I think they are called swing arms but not sure. They are made aftermarket so you can go through any of the suppliers and get them.
The tool kit can be put together from the different pieces found at swap meets or antique stores. A kit is not 'reproduced' per se, I don't have one as I use modern tools instead that I keep in the car with me.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-04-2012, 06:26 PM   #3
CarlG
CarlG's Avatar
Here are a couple of parts you need: (scrol over the pictures for Snyders Part #'s)
Old 04-04-2012, 06:32 PM   #4
Ron in Quincy
Ron in Quincy's Avatar
If some one has not removed the hardware, there should be a threaded stud on each side of the inside body to attach the swing arm; there should also be brackets on the inside of the windshield at approximately the same height as the studs that the other end of the swing arm attach too.
Ron
Ron in Quincy is offline   Reply With Quote
Old 04-04-2012, 06:37 PM   #5
jmeckel
jmeckel's Avatar
Here are more of the parts
Nuts that allow arms to be adjusted
Bolt set that are used to attach swing arms to the window frame
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 04-05-2012, 08:42 AM   #6
Kevin in NJ
For the tool kits you just need to look around at garage sales and other local events.
They made millions of tool kits and everyone kept the tools. The key is to know how to identify the tools. Few are Ford script. The jacks are size specific. The company may have made the same design in many different sizes. So a jack that is 1/2" too short will not be the correct jack, no matter how many judging certifications the guy selling it tells you he has.
So look in the tool boxes at garage sales. Odds are real high you can find most of the tools in the $.25 range. Except some will try to get a a premium for the spark plug wrench cause they can be Ford script. Then you just remind them there are 4 million of these wrenches out there.
Now nice screw drivers and pliers I will pay as much as a dollar for them cause people will pay more for them. I will also pay more than a dollar for a nice tire pump, crank, and any jack.
