Old 06-16-2019, 08:15 PM   #1
Crabby
Default 36 Car Headlight buckets
My clips at the bottom have broken off on both buckets. Just wondering if anyone has a good repair for this. I’ve searched the board and can’t seem to find this question before. I doubt I’m the first one this has happened to. I was thinking of using small diameter short screws and a nut run up tightly to the bottom of the bucket. I’d hate to do that if someone has a better suggestion. Thanks!
File Type: jpg C73D4D9B-0BED-4771-B0E4-7C03D772DAF5.jpg (23.9 KB, 48 views)
Crabby is offline   Reply With Quote
Old 06-16-2019, 09:41 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 36 Car Headlight buckets
Try looking in the model A parts places like Brattons,Snyders
Old 06-16-2019, 09:56 PM   #3
Crabby
Thanks!
Old 06-17-2019, 03:12 AM   #4
deuce lover
deuce lover's Avatar
You might have to make them.Here is a pic of a '35 head light bucket.You can see that they are riveted.
deuce lover is offline   Reply With Quote
Old 06-17-2019, 03:27 PM   #5
RalphM
RalphM's Avatar
Does this help?
This is Bob Drake, but others carry them.
File Type: jpg DF2C93FA-3515-4E90-9812-4A6C59E6465B.jpg (6.7 KB, 41 views)
RalphM is offline   Reply With Quote
Old 06-17-2019, 04:02 PM   #6
Crabby
Thanks, everyone. I ordered the ones from Bratton last night. Hopefully they’ll work. Otherwise, I’ll make something to hold it.
Old 06-18-2019, 05:08 PM   #7
Gary Tosel
Gary Tosel's Avatar
Just to clarify the Drake kit shown is for the latch on the headlight trim ring and not the head light bucket itself.
Gary Tosel is offline   Reply With Quote
Old 06-18-2019, 08:12 PM   #8
Don Rogers
Don Rogers's Avatar
The Bratton clip should do the trick with a few holes drilled for rivets
Don Rogers is offline   Reply With Quote
Old 06-20-2019, 05:24 AM   #9
oldandtired
Crabby...If fixing yours doesn't work out for some reason, Dennis Carpenter has quite a few 36 passenger buckets in their NOS department. There are a few 40/41 seal beam buckets mixed in with the bunch, on the shelf. I do not believe that they are NOS, but they all appeared to be good buckets when I looked through them in April.
oldandtired is offline   Reply With Quote
