04-16-2013, 07:07 AM | #1 |
V8 water pump
The water pump on my 29 Roadster with an A motor just went out. I bought the car about a month a go. so is there a place that I can get a new water pump with the pulley set up on it. their is also a Clings serpentine belt and fan on it also. can you help ne out? thanks, Brendan
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
04-16-2013, 07:58 AM | #2 | |
Re: V8 water pump
I also am not sure if you have a V-8 pump with an adapter or a regular-style Model-A pump. Generally speaking, if a serpentine belt is used on a regular Model-A pump, the natural tendency is to tighten the belt too tight which ruins the front bearing on the pump. With that said, I also do not see a value in a serpentine set-up. I do see the value in a race car application where parasitic Hp draw is a factor but when the original belt is properly installed, the Hp consumed is negligible and the water pump wear is all but eliminated. Might I suggest if possible that you revert the system back to an original style pump, fan, and belt system. |
04-16-2013, 08:13 AM | #3 |
Re: V8 water pump
Sacramento Vintage Ford Pt number 5733
04-16-2013, 08:39 AM | #4 |
Re: V8 water pump
I agree with Brent, and an original pump is easy to rebuild. I rebuilt mine about 15 years ago and have been running it for the past ten years without leaking a single drop.
Last fall, after the vinegar rust removal treatment, I installed a rear bushing with the seal in the back of it. This will keep the grease and antifreeze from mixing with each other. My old used temporary engine had an accumulation of rust in the rear of the block. After years of running many of the rust flakes came loose and plugged the radiator until coolant came out the overflow. I also installed a drier sock to trap any future rust that may be remaining, but I feel confident that 30 days of running pure white vinegar got rid of the rust. |
04-17-2013, 09:54 AM | #5 |
Re: V8 water pump
Brendan, How about using the whole V8 Motor instead
of only one V8 water pump ? Then you would have an A-V8 . Rich ..............
36Panel Delivery |
04-17-2013, 10:45 AM | #6 | |
Re: V8 water pump
....and the benefit would be??? . |
04-17-2013, 11:46 AM | #7 |
Re: V8 water pump
04-17-2013, 06:44 PM | #8 | |
Re: V8 water pump
04-17-2013, 06:47 PM | #9 |
Re: V8 water pump
so what do you guys think about the V8 pump , have other guys had trouble with them?
can you let me know? their is about 1/4 inch of play in the pump the bushing failed
04-17-2013, 07:40 PM | #10 |
Re: V8 water pump
hope this helps
04-29-2013, 06:47 PM | #11 |
Re: V8 water pump
i wont to put on a Model A water pump on my car, so where can i get a Cling serpentine pulley for a Model A pump? i don't wont to change all my pulleys . can you guys help me Thanks Brendan
04-29-2013, 07:33 PM | #12 |
Re: V8 water pump
so what do you think!
04-29-2013, 07:57 PM | #13 |
Re: V8 water pump
04-29-2013, 08:04 PM | #14 |
Re: V8 water pump
Call Cling's and see if they'll sell you one. They make a kit "KIT B" for stock Model A with alternator - https://www.clingsaftermarket.com/addtocart.asp?prod=32
And I'm still interested in that Cyclone pump adapter |
04-29-2013, 10:03 PM | #15 |
Re: V8 water pump
yes, all the pulleys are serpentine. I would like to just change the water pump and the water pump pulley
04-29-2013, 10:05 PM | #16 | |
Re: V8 water pump
04-29-2013, 10:14 PM | #17 |
Re: V8 water pump
What other belts do you have on the engine that you want to match them?
04-29-2013, 10:22 PM | #18 |
Re: V8 water pump
the crank pulley and the pulley on the alternator, are serpentine also the one for the V8 water pump. I would like to get a serpentine pulley for a Model A water pump. I bought a V8 pump from Dennis Carpenter but the shaft is to big and the housing is very different from the old pump, after reading and thinking about this I think that a model A pump is the way to go. but I just wont to change the pulley on the water pump
04-29-2013, 10:26 PM | #19 |
Re: V8 water pump
I have spare v8 pumps, spare adapters, one has adapter with v8 pump & plastic fan.
Looking at your set up has correct belt to run orig A pump, |
05-02-2013, 06:10 PM | #20 |
Re: V8 water pump
The email in the newest Restorer is [email protected]
