01-22-2016, 09:41 AM | #1 |
the new model a ford alternator
any pros and cons on the new alternators for the model a,not the one that looks like the generator,one I saw looks more like GM,looks very nice
01-22-2016, 09:52 AM | #2 |
Re: the new model a ford alternator
I recently installed the Powermaster alternator (6v pos ground) a purchased from Jegs. I love it. My battery stays much hotter than before. My generator was not a Model A generator. I'm not sure where it came from. It was on the car when I purchased it.
Ryan Scardina Livingston, Louisiana 1930 LSU Model A |
01-22-2016, 10:42 AM | #3 |
I have a Nu-Rex 6 volt positive ground alternator on one of the A's. It has about 10K miles on it and has been flawless and maintenance-free.
The best part is, if you want to change back to a stock generator, it is quick and easy since you don't have to modify anything to install the alternator. |
01-22-2016, 10:52 AM | #4 | |
01-22-2016, 11:01 AM | #5 |
Whatever you buy, make sure the alternator is self starting. If not, you will be revving the heck out of your engine to get the alternator to charge. So be sure to ask the question, "Will the alternator self-start at idle without having to rev the engine?"
Bob Bidonde |
01-22-2016, 11:39 AM | #6 |
01-22-2016, 11:04 AM | #7 |
The GREAT thing about an alternator is that your battery is ALWAYS FULLY CHARGED! !
Bill W.
01-22-2016, 11:08 AM | #8 |
Why do you even need an alternator?
I know I keep rehashing this. The alternator is just a cash cow for the dealers. The alternators can not really produce the power they say for the duration (go look it up about how the alt produce power and what size pulley you need, Google will tell all). All are installed with the belt not tight enough and the pulley too small to produce power properly. The alternators are not as reliable. The smaller pulley is more likely to fail the belt. You can run direct replacement halogen bulbs with a generator just fine. Keep in mind the generator on my brothers car was rebuilt by him when he was 15 years old. It has not been off the car for any repairs since 1970 when a temporary repair was done for the flung solder. He does not have a regulator and often has gotten more then 5 years on a battery, including battery's taken off the dead battery pile. He has been running halogen headlights for many years now so he can run 55 MPH at night. He is still running with the same belt from 1970. So what is it that you need an alternator for because the generator can not do the job? Do it right once and never worry again. Save lots of money too. BTW, do a scan and see how many people have had problems with their alternators on this board. |
01-22-2016, 11:59 AM | #9 | |
01-22-2016, 02:14 PM | #10 |
How come Modern Cars ALL run Alternators? Poor old generators just STRUGGLE to BARELY do the job. How come we don't still have the OLD CRANK TELEPHONES???? or OUTHOUSES??
Bill W.
01-22-2016, 02:21 PM | #11 |
Installed a Nu Rex 6 volt positive ground alternator 4 years ago and it has been trouble free since the install . Just start and drive.
01-22-2016, 02:27 PM | #12 |
I have an alternator on my pickup its been on there for 10 years and just fine,what I'm thinking on is for my doodlebug and Ken Davis has a new not rebuilt Alternator set up, planning on buying, just wondering maybe others have bought,I bought his shocks quite awhile back and there just great.
01-22-2016, 07:03 PM | #13 | |
& I can also attest to his Modern Shock kits.
Cowtown A's |
01-22-2016, 03:56 PM | #14 |
I put a Powermaster alternator on my town sedan. Battery always has a good charge. Maybe not necessary, but with halogen bulbs, I thought it would help. I am no expert, but I notice an improvement. I held on with my old generator for a long time, but with a long trip in the planning, I thought it would be good to upgrade. After 6 months, no probs, yet!
01-22-2016, 04:05 PM | #15 |
My 28 still runs it's original generator and has been totally trouble free for me, and it's kept my battery fully charged. Do what you want with your car, but an alternator isn't needed. I've never had to replace or rebuild a generator on my cars, but have had alternator burn out diodes. When I buy a car I like to restore the 5 ancillaries just as preventative maintenance.
That is: Water pump Carb Distributor Starter Generator With these 5 parts restored there is little chance of a roadside breakdown because of them. It's winter and most of us don't drive in the road salt season, so do one part each weekend, and in 5 weeks you'll have a more reliable car. Last edited by Tom Wesenberg; 01-22-2016 at 09:27 PM. |
01-22-2016, 06:20 PM | #16 |
I have an alternator shop but run a generator.
Maybe because its the least of my problems.....They just look wrong..
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
01-22-2016, 07:06 PM | #17 | |
Is there a way to convert the Stock Generator to 12v?? Have not noticed anything from the vendors (I don't suppose this would be too common. |
01-22-2016, 09:07 PM | #18 | |
A STOCK generator is capable of putting out up to 45 VOLTS! ( Not continuous, though.) Bill W.
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 01-24-2016 at 12:55 PM. |
01-22-2016, 09:09 PM | #19 |
Mike's sells 12 volt field coils http://www.mikes-afordable.com/product/A10000FC12.html I don't know what else would be needed, and a guy on the e bay sells rebuilt 12v generators.
01-23-2016, 11:43 AM | #20 | |
I don't like the looks of an alternator on my Model A but one advantage to having a common GM alternator is IF something happens out on the road, most any parts store should have one in stock. Don't think they carry Model A generators. |
