Old 08-01-2018, 08:11 AM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default V-Belt Cross Ref
I have a '40 59ab that needs a new main belt. I have a Napa belt in my trunk that I put in there as a spare, Napa number 25-20544. It's a 5/8" width belt.
When I look up what I need I see a number 27666 belt is what is needed. Are they one in the same?
The present belt has probably stretched but here is an issue I have. I am running a "Y" 2-deuce progressive intake that the generator hits the bottom of the front carb leaving the belt somewhat loose as I cannot tighten it enough. Is there a slightly shorter belt I can use to take up that slack? I am running the newer sealed bearing water pumps ...
Thanks for any help you can give ...
PS - I think the 27666 belt is for the front mount fan I have - it's 37"
The Napa belt 2520544 is 54.73" long and that should be the main belt replacement BUT is there one slightly smaller?
TomT/Williamsburg is offline   Reply With Quote
Old 08-01-2018, 09:31 AM   #2
markdtn
markdtn's Avatar
Default Re: V-Belt Cross Ref
Gates B52 is a 55” belt. B50 and B51 are 53” and 54”.
markdtn is offline   Reply With Quote
Old 08-01-2018, 09:34 AM   #3
TomT/Williamsburg
Thanks!
Old 08-01-2018, 01:31 PM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Tom , The napa store has a chart for that belt , i just went thru it on my flathead engine,i think mine was a 252055 (55 inch) for a late flathead with alternator..
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 08-01-2018, 01:45 PM   #5
rotorwrench
rotorwrench's Avatar
I think the old Ford belts were nearer 11/16" wide originally. Most of the new stuff is based on new part standards. They have gone to metrics pretty much.
Old 08-02-2018, 08:11 AM   #6
deuce lover
deuce lover's Avatar
Took a pic of a chart I have originally posted by 35tn.Print it out -worth having in the drawer of the tool box.
deuce lover is offline   Reply With Quote
Old 08-02-2018, 09:05 AM   #7
Kahuna
Kahuna's Avatar
Tom
On both my 39 & 32 Fords, I run Machine belts from the Hardware store.
On the 32, I used the original motor mounts, and by using a machine belt,
I didn't have to grind the mounts, as the belt fits into the pulleys deeper.
Machine belts are also available in incremental lengths.
I think Rotorwrench is correct in that Ford belts are 11/16 & the hardware
store belts are 5/8's..
Now, some say these belts won't work well or last long. The 39 has had one
for 26 years & the 32 for about 7 or eight. Should one fail, you're only an
ACE Hardware store away. Cheap too.
Jim
Kahuna is offline   Reply With Quote
Old 08-02-2018, 09:27 AM   #8
flatheadmurre
flatheadmurre's Avatar
I´ve been running B52 or B53 depending on size of generator pulley for years...no issues with them wearing out fast.
Fan belt for newer trucks is B35.
