Old 01-20-2020, 08:54 PM   #1
Ziggster
Default Looking for exhaust port layout drawing
I'm looking for a drawing of the exhaust port layout so I can fab up a plate for my engine stand. I've searched but I couldn't find anything on the net. If you have one, or if you could point me in the right direction, it would be much appreciated.
Ziggster is offline   Reply With Quote
Old 01-20-2020, 08:56 PM   #2
JSeery
JSeery's Avatar
Default Re: Looking for exhaust port layout drawing
I would think an exhaust gasket as a pattern would be the way to go, that is what I did when I fabricated one. (brain short circuit, this will not work with a flathead, individual gaskets!). Another way to go about it is use some light card stock type of material and do an impression directly off the block. You just need the outside four bolt holes. Some examples (not mine).
Old 01-20-2020, 09:47 PM   #3
tubman
tubman's Avatar
Who makes flathead exhaust gaskets that are one piece per side? I have only seen the individual port kind.
Old 01-20-2020, 10:25 PM   #4
Tinker
Tinker's Avatar
Take some grease and put a slight amount around the area (or spray WD40). Press the gasket/template material up to it. Boom... template.
Works the same with some paper taped to the spot and a dirty finger rubbing over the area. Like a art "rubbing'.
https://en.wikipedia.org/wiki/Rubbing
***You're probably looking for a waterjet ready eps/dwg/vector. Not sure on a link, I could make one, no block not used for me***
Old 01-20-2020, 10:39 PM   #5
RalphM
RalphM's Avatar
I just used an exhaust manifold for the pattern. Of course you must reverse it, unless you’re using it on the other side
RalphM is offline   Reply With Quote
Old 01-20-2020, 11:27 PM   #6
cas3
exhaust manifold and transfer punches.
cas3 is online now   Reply With Quote
Old 01-21-2020, 03:38 AM   #7
Ziggster
Thanks for the suggestions. The problem I have is that I don't have a manifold, and the gaskets I have are the individual ones for each port. I have the engine, but it is all wrapped in plastic which I don't really want to remove just yet as I still need to clean up my workshop which is a total mess.
Old 01-21-2020, 08:28 AM   #8
JSeery
JSeery's Avatar
To answer your original question, I don't know of any pattern that is available. It is too easy to make one. Might get someone with a head or block to make you one.
You could go ahead and get the manifolds you intend to use?
Old 01-21-2020, 08:30 AM   #9
JSeery
JSeery's Avatar
ya, slipping into my OHV thinking!
Old 01-21-2020, 08:51 AM   #10
Ziggster
My machinist had a block. I’ll see if i can arrange to have access so I can trace out a pattern.
Old 01-21-2020, 08:54 AM   #11
JSeery
JSeery's Avatar
It is fairly easy and quick to hold some poster board type of paper up to the block and just use your finger to press around the bolt holes. Just make sure the paper stays put and doesn't move.
Old 01-21-2020, 09:15 AM   #12
RalphM
RalphM's Avatar
Or, screw four studs in the outer ports and lay the poster board on them, slight tap with a hammer and viola!
Old 01-21-2020, 09:24 AM   #13
Mart
Mart's Avatar
Make all the holes bigger than 7/16" so the adaptor can fit both sides. 1/2" is ok.
Old 01-21-2020, 09:52 AM   #14
corvette8n
corvette8n's Avatar
Got mine from Stumpy
https://www.stumpysfabworks.com/stor..._Products.html
Scroll down to flathead.
It's 4 below zero and I have a flathead mounted on mine in a portable garage, otherwise I'd make a cardboard tracing of mine and sent it to you. Maybe if your still looking I do it in the spring. Pm me if your interested.
Old 01-21-2020, 10:33 AM   #15
Fordestes
I take some grade 5 bolts cut the thread part off , grind the flat cut off end to a point , screw the bolt ends in the block put some tool makers ink, magic marker ,momma's cake coloring etc. on the ground pointed ends protruding from the block, grabbed a 1x4 and a mallet tapped the board against the pointed studs then drill the 1x4 as a template and transfer punch a 1/2'' plate for the block mounting flange , I take a 2'' piece of cold rolled cut to 45 degrees weld to the 1/2'' plate to fit my engine stand head. I keep a selection of different pointed bolts used to transfer bolt patterns ,I also set some threaded cut off bolts up in a lathe then drill through the center and use as a starting guide for center drilling bolts that are broken off below the surface such as head bolts.
Fordestes is offline   Reply With Quote
Old 01-21-2020, 11:40 AM   #16
Tim Ayers
What's your mailing address?
I'll just trace my angle adapter and mail it to you.
Old 01-21-2020, 03:20 PM   #17
frnkeore
frnkeore's Avatar
This is the Ford drawing. A little hard to read with this upload but, the center distance is 7.812 or 15.624, end to end. 1.437 or 2.874 on the flange holes, set at 30 deg.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 01-21-2020, 03:44 PM   #18
johndee138
johndee138's Avatar
You want a tracing off of my Stumpy mount, or a header? I could do that for you.
johndee138 is offline   Reply With Quote
Old 01-21-2020, 04:22 PM   #19
JSeery
JSeery's Avatar
That should do it! Good post.
Old 01-21-2020, 04:39 PM   #20
Ziggster
Excellent. Thanks guys. Between the drawing and my gaskets, I should figure it out. Trust me, if I lived in the USA, I would have just purchased one, but with the exchange rate, taxes, and brokerage fees, it gets spendy fast. I'll post up pics when I'm done, hopefully in the next week.
