Old 07-12-2022, 08:51 AM   #1
std1940
std1940's Avatar
Default 1940 gear oils
I am planning on changing my transmision and rear end fluids in my stock 1940 Ford Standard Coupe.
What is everybody using to make the 82 year old components happy?
Brands and weights?
Thanks Tom.
std1940 is offline   Reply With Quote
Old 07-12-2022, 09:20 AM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 1940 gear oils
I use 85-90 wt and you really need GL4 if you can find it. It’s not hard on the brass parts in the transmission.
Old 07-12-2022, 09:33 AM   #3
Bill OH
I use 90w and a max of GL4 - stay away from GL5 in the transmission, ruins brass synchros.
Bill OH is offline   Reply With Quote
Old 07-12-2022, 11:55 AM   #4
19Fordy
19Fordy's Avatar
I use this in my 1940 Ford transmission and rear end.
https://www.oreillyauto.com/detail/c...ar+lube&pos=11
For winter driving you may want to use a lighter weight GL4.
https://www.oreillyauto.com/detail/c...ar+lube&pos=13
I have found Oreilly sells this product at the lowest price.
Old 07-12-2022, 02:56 PM   #5
Ford Freak
For years now I have used Sta-Lube GL4 / 140wt. in trans & rearend. I get it@ NAPA.- F F
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 07-12-2022, 07:36 PM   #6
Tim Ayers
85W-90 Sta-Lube GL-4 can be ordered in from any Napa dealer.
Old 07-12-2022, 09:00 PM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
Gear oils labeled both GL4/GL5 should also be safe.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn.
FL&WVMIKE is offline   Reply With Quote
Old 07-13-2022, 10:04 AM   #8
std1940
std1940's Avatar
Thank You everyone for your wealth of advice!
Old 07-13-2022, 10:32 AM   #9
rotorwrench
rotorwrench's Avatar
GL-5 is high EP and the extra pressure additive can be harmful to the soft metal bushings and thrust washers in a transmission. It works fine in the rear axle though unless you have a model T.
Old 07-13-2022, 12:56 PM   #10
FL&WVMIKE
FL&WVMIKE's Avatar
One more thing to add... For those wanting a high performance GL4 oil, Brad Penn/Penngrade sells a nice formulation... for a reasonable price. Below are links to places that it.
One specializes in Ford Toploader transmissions, but it can be purchased at other places as well. Summit is the cheapest at $8/qt. Can read reviews at Summit.
http://4speedtoploaders.com/store/gearoil.html
https://www.summitracing.com/search/...n%20gear%20oil
Old 07-13-2022, 08:00 PM   #11
Ken/Alabama
Or a Columbia.
Old 07-14-2022, 07:14 AM   #12
Terry,OH
Terry,OH's Avatar
Columbia has brass washers at the spider gears and both thrust faces of the axles. IMO stay away from the GL-5 in the Columbia.
