Old 08-18-2019, 07:02 PM   #1
50droptop
Default 1936 Rear window gasket question
This may sound like a silly question, but where should the 2 ends on a 1936 5W rear window gasket meet? Should the seam be at the top of the window or the bottom? Also, is anyone applying window sealer to the window gasket groove itself (sealing gasket to window) or just applying the sealer to the body then setting the window in place?
50droptop is offline   Reply With Quote
Old 08-18-2019, 07:26 PM   #2
swedishsteel
Default Re: 1936 Rear window gasket question
Originally that rear window rolled up and down. If yours doesn't it has been changed, so do what ever you think will keep it from leaking. Rod
swedishsteel is offline   Reply With Quote
Old 08-18-2019, 07:31 PM   #3
50droptop
This is a trunk car, so the rear window is fixed. I understand only the rumble cars had the roll down windows.
Old 08-18-2019, 07:33 PM   #4
Don
Don's Avatar
My 36 has trunk and roll down window,,,,,all .org.
DON P
Don is offline   Reply With Quote
Old 08-18-2019, 09:56 PM   #5
Gary Tosel
Gary Tosel's Avatar
I located the rubber joint at the bottom of the rear window.
1/4 windows I used the one piece rubber seal design from Drake.
The seal between the rubber seal and the body I used 3M black Strip-Calk part number 051135-08578 which shows on the package this type of application.
In addition, this rope type calk does not get hard with age and is a great seal. It is like modeling clay and you can roll it into strips and is easy to install.
I talked to a company that cuts auto glass windows and installs them. The owner had many years of experience and he told me never to use silicon caulk between the steel body and any glass, since he claimed silicon will hold moisture and promote rust.
Gary Tosel is offline   Reply With Quote
Old 08-19-2019, 05:45 AM   #6
50droptop
Thanks Gary! This is great info.
Old 08-19-2019, 03:38 PM   #7
Brad Boyer
My 36 Coupe with trunk has a rolldown rear window too.....
Brad Boyer is offline   Reply With Quote
Old 08-19-2019, 04:09 PM   #8
RalphM
RalphM's Avatar
So does my 35 3W
RalphM is offline   Reply With Quote
Old 08-19-2019, 04:44 PM   #9
50droptop
Not sure fellas...maybe it's a Standard vs Deluxe thing. One thing I know is this is an original (unrestored) Standard 5W coupe with no roll down rear window.
Old 08-19-2019, 06:46 PM   #10
RalphM
RalphM's Avatar
I would say gasket joining at the bottom.
Maybe it is the deluxe versus the standard thing. Don Rogers would know all about it.
Hey let’s see some pictures of that 36, how’s it coming along?
Old 08-19-2019, 07:38 PM   #11
50droptop
Coming along nicely. Body (with original paint) is polished and ready to go back on the chassis. Chassis is almost complete, only need to work out the exhaust connection around the Early V8 Garage juice brake setup. Garnish and dash has been cleaned, lightly wet sanded and prepped for clear. Dash and garnish are the only pieces that will receive clear coat; NONE for the body. I’ve included a quick snap of the glove box door when it was wet. This is what it will resemble after clear. Here’s some recent photos.
Old 08-19-2019, 08:20 PM   #12
RalphM
RalphM's Avatar
Looking good! Amazing you were able to bring all that original paint back to life, and the dash is going to look beautiful!
Old 08-19-2019, 10:09 PM   #13
TagMan
My '36 3w trunk car has a roll up rear window.
TagMan is offline   Reply With Quote
Old 08-20-2019, 12:09 AM   #14
rustythumb
on standard coupe with trunk- roll down window was an option.
rustythumb is offline   Reply With Quote
Old 08-20-2019, 12:13 AM   #15
Tinker
Tinker's Avatar
I have a trunk on my 36 and the window rolls down. Can't answer your question on seals. Not there yet.
Best of luck? Looks nice
