09-02-2017, 03:47 PM | #1 |
Magneto Question
When I switch the ignition switch to magneto the car stops running, can any one tell me what I should be looking for to diagnose the problem? I am driving a 1926 Ford Model T coupe. I bought the car this way. It runs great and is in awesome condition, so I would like to make sure everything works in the car.
Mark Papa |
09-02-2017, 04:14 PM | #2 |
Re: Magneto Question
First test at the mag post on the hogs head for AC voltage while running. It should increase with higher RPM. If it has running voltage next check the batt/mag switch and wiring for any open or bad connections. Report your findings here.
09-02-2017, 05:39 PM | #3 |
You need to use an analog meter, standard digital type will not work because of interference from the mag using . Start also by checking connections.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 09-02-2017 at 07:52 PM. |
09-02-2017, 06:29 PM | #4 |
If very low or no voltage out of mag plug, remove the mag plug and check for lint on the end of the plug. They sometimes collect lint from the band material. If no lint and no voltage, your magnets are probably bad. They can be recharged. John
11-30-2017, 02:03 PM | #5 |
John Are you the Model T guy from Rhinebeck NY LOL I know you well old buddy! You have model T bands in your blood.
11-30-2017, 06:08 PM | #6 |
11-30-2017, 09:23 PM | #7 |
While doing this testing, make darn sure that you don't accidentally allow DC voltage to enter the mag post. If your magneto is alive now- it won't be after the accidental DC voltage makes contact. The magnets will be de-magnetized.
Just a friendly warning. I wish someone had warned me! |
11-30-2017, 09:46 PM | #8 |
As the magnets can be discharged in the car so can they be charged, it in the book. you can use any volt/ohm meter while the car is not running.
02-09-2018, 05:11 PM | #9 |
What would cause a magneto to suddenly die? I recharged my own magnets, shimmed and installed, and was running great. One day the car died on the mag side while driving. I checked the mag post and no lint. No noise in the transmission running on battery. What happened? Thanks
02-09-2018, 05:20 PM | #10 |
They read "Silas Marner" while you were driving
02-09-2018, 06:51 PM | #11 |
I would check the ignition switch to see if there is a loose wire. How long ago did you recharge the magnets. They can loose strength. What is your method for recharging? You should follow the directions in the Dyke's manual to be sure they are charged completely. I think, if I remember right, you need 36 volts to charge the magnets in the car. You also need a compass to be sure to get the correct north and south poles to line up. John
