Old 02-14-2020, 01:47 PM   #1
russcc
Default Blast media
I have used glass bead in my machine in the past, and black beauty in another blaster that I tend to use outside. I just tried out aluminum oxide, (black), I believe it was 70 grit, from H Frt. What I found is, that is was very dusty, but it worked well on some light rust. Also, I found it was magnetic, which if it's non-ferrous, how could that be. Anyone have experience with different Almn. oxide media they can share.
I was experimenting with it because that's how the plating shop preps fasteners for Parkerizeing. Someone here mentioned that the Parkerizing they use rusted. The secret to a good durable finish is to heat Parkerized items in liquid grease or other lubricants which get's embedded in the finish. Thank you Fordbarners.
Old 02-14-2020, 05:11 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Blast media
Try crushed glass, also limit the pressure to under 50lbs pressure
Kurt in NJ is online now   Reply With Quote
Old 02-14-2020, 05:30 PM   #3
RalphM
RalphM's Avatar
I use the crushed gas, used to use the black stuff, but as you said dusty, I couldn’t see what I was cleaning very well, and I have a vacuum.
RalphM is offline   Reply With Quote
Old 02-14-2020, 05:36 PM   #4
cas3
i cant imagine 50lbs doing anything! i stop blasting when the compressor come on at 110 or so. glass beads, dusty as hell
Old 02-14-2020, 05:49 PM   #5
39portlander
39portlander's Avatar
Check with TP tools in Ohio, I got my cabinet through them with Skat magic that is quick but dustier than others due to content of the media.
This spring I will be switching to their newer abrasive, Fast-Cut max that claims to have a reduced dust level and works good on paint, rust and scale.
They have another media I may try, Speed bead abrasive that leaves a more sating smooth finish, good luck and let us know how you make out.
39portlander is offline   Reply With Quote
Old 02-14-2020, 06:04 PM   #6
35fordtn
35fordtn's Avatar
I have four media blasters and use different in Each. Coal slag is cheapest ($6) for 50lbs but is dusty and doesnt last very long. I use it in my automatic blaster...
Glass beads are my go to for generic blasting I buy it from Zoro Tools as I like it better than what TP Tools sells and its free shipping.. I buy A LOT of it in a years time.
My automatic blaster I run at 40LBS and my cabinets I run at 95LBS and My outdoor blaster I run at 120
https://www.zoro.com/ballotini-blast...40/i/G3365415/
Old 02-14-2020, 08:07 PM   #7
swedishsteel
i use generic silica sand that Menards handles--about $5 for 50 lbs. Have tried glass beads, and that black stuff. Glass beads worked good on aluminum with lower pressure as it isn't quite as aggressive as sand. Have a bench top cabinet, 100 lb pressure pot and small siphon feed. When it gets too dusty in the bench top, I use that outside in the pressure pot to save a few dollars. Only time you have to be careful with pressure on steel/iron is on sheet metal, as it will warp. I have a 60 and 80 gallon compressor that work together when I'm blasting a lot--can hold 120 lbs, they shut off at 140. Nothing like a sand blasted surface for good paint job.
swedishsteel is offline   Reply With Quote
Old 02-15-2020, 06:52 AM   #8
russcc
Thank you all for your comments and ideas. I use glass bead in my cabinet machine at 90-125#s, and it work fine for light steel and alum. blasting. The black beauty I use outside in a portable machine. Nothing is a dusty as that crap I got from HF, Just wondering if that is typical from Alum. oxide.
Old 02-15-2020, 07:19 AM   #9
Ziggster
I've used some kind of black oxide (slag?) in the past on a neighbours boat trailer. It was dusty for sure, but we are out in the country so no issues. I really didn't like it either for mild rust, and have been using glass bead now for several years. Still very dusty, but I find it gets rid of rust (heavy pitted type) very well. It also leaves a nice surface finish depending on the size. I do mine outside in a "tempo" (temporary) garage, and recycle it.
Ziggster is offline   Reply With Quote
Old 02-15-2020, 08:15 AM   #10
john in illinois
john in illinois's Avatar
I have tried a lot of different media in my Trinco blast cabinet. Walnut shells are good for aluminum motorcycle engine parts.
I now use Trin Mix which is glass beads with aluminum oxide. It works fast and leaves a glass bead satin finish. It leaves a nice finish for parkerizing.
https://trinco.com/abrasives-media/
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 02-15-2020, 06:26 PM   #11
Peterooster
Peterooster's Avatar
Carbide lasts forever. Pete
Peterooster is offline   Reply With Quote
Old 02-15-2020, 06:30 PM   #12
Peterooster
https://www.mcmaster.com/blasting-media
not cheap, but lasts. Pete
Old 02-16-2020, 11:49 AM   #13
outlaw
This is what I use at home & at work.
outlaw is offline   Reply With Quote
Old 02-17-2020, 01:17 AM   #14
deuce_roadster
deuce_roadster's Avatar
For paint and rust I use 80 grit garnet at 90 lbs. For aluminum I use glass beads at 40 lbs, things like armatures walnut shells at low pressure. This is an old Scat Blast cabinet I have used for over 20 years, have worn out 2 vacuums.
Old 02-19-2020, 04:14 PM   #15
grumppyoldman
grumppyoldman's Avatar
I've used several blast media's in my cabinet machine. Glass bead just disappeared into the vacuum and didn't do a good job. The best I found was aluminum Oxide ( Starblast XL ) the only place it's available is Victoria Gas in Victoria Tx. they keep a supply for Dow Chem. there, but I don't know if it would be too expensive to ship elsewhere. It puts a good tooth in the metal and would probably warp it is used to aggressive. Al
grumppyoldman is offline   Reply With Quote
