Old 04-25-2019, 12:16 PM   #1
steward614
Default Radiator Shell Badge Mountin...How to??
Hello I have a 31 radiator shell and purchased an aftermarket black script FORD top badge to be installed. It has the "cup" behind. Whats the best way to flare the cup without damage to install?
Steward
31' Ford Phaeton
steward614 is offline   Reply With Quote
Old 04-25-2019, 02:22 PM   #2
Will N
Will N's Avatar
Default Re: Radiator Shell Badge Mountin...How to??
I believe that with original parts, that cup is a snap-in fit into the hole in the shell. But if yours is lose, maybe some silicone to hold it?
Will N is offline   Reply With Quote
Old 04-25-2019, 02:50 PM   #3
J Franklin
J Franklin's Avatar
It should pop in and stay, adhesive if not.
Old 04-25-2019, 11:27 PM   #4
duke36
I have a repro that the cup separated from the front logo portion poor rivet assembly. GE Silicon sealant has held well
Old 04-27-2019, 09:04 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
My first choice for badge to cup separation would be to rough it up and use JB Weld. As mentioned, the cup should be a press fit to the shell.
