11-06-2023, 10:24 AM | #1 |
Arguementive Lubrication of The Model "A" & "AA"
When the subject is lubrication of any sort, I recommend that you disregard vintage factory service bulletins, vintage manuals and word-of-mouth touting old time lubricants. Lubricants before 1960 have obsolete technology that can be deleterious to vintage vehicles. This is especially the case with vintage motor oil, vintage gear oil and vintage chassis / wheel bearing grease.
The most significant advances in lubricants are improvements in heat resistance, seasonal temperature accommodation, friction reduction, wear resistance, shelf life, service life, anti-sludge formation and there are other improvements. The jet age and WW2 brought about synthetic lubricants that have spectacular high temperature performance and wear resistance. I practice what I preach and have been using the most modern technology lubricants since 1962. Not once have I experienced a failure due to the use of modern lubricants in my Model A's.
Bob Bidonde Last edited by Bob Bidonde; 11-06-2023 at 10:33 AM. |
11-06-2023, 11:01 AM | #2 |
Re: Arguementive Lubrication of The Model "A" & "AA"
11-06-2023, 11:10 AM | #3 |
Ok, I tend to agree with you. Can you give me a recommended schedule.
11-06-2023, 01:08 PM | #4 |
This stuff is amazing. I discovered it at work and used it on bearings under high heat conditions. Other greases failed in weeks, this stuff lasted years on the same bearings. Now, I use it for everything that requires grease.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
11-06-2023, 09:15 PM | #5 |
Bob, what motor oil do you recommend? Transmission oil? Rear end oil? I know this subject is the source of endless debate.
David in San Antonio 1930 ('31?) Deluxe "Wretched Roadster" Restored 1957 Alamo A’s Club |
11-07-2023, 09:25 AM | #6 |
Motor Oil: I use Walmart's Syntech Synthetic Blend 10W40 or whatever is on sale for the lowest price. No additives. I drive about 2000 miles per year, and my A's do not have oil filters. Wheel Bearings, Chassis, Steering, U-Joint & Shock Links: Valvoline Grease fortified with Molyptinum Disulfide. Greasing is done once per year. Shock Absorber Fluid: Syntech Automatic Transmission Fluid, and when they become worn I use STP. Shock fluid is replenished once per year. Transmission & Differential: Walmart's Syntech 85W140 GL5 Gear Oil that I change about every 10,000 miles. Steering: Sector bushings are greased with Valvoline Grease. The gear box is filled with STP.
Bob Bidonde |
11-07-2023, 09:40 AM | #7 |
Don't know about a Model A but I use John Deere corn head grease in the steering box on my '39 p/u.
Making the simple complicated for over 30 years. |
11-08-2023, 04:41 AM | #8 |
I use the John Deere Corn Head Grease in the u-joint and steering box.
11-08-2023, 08:05 AM | #9 |
I tried corn head grease in my steering gear box ( two tooth) , it got very tight to turn. Removed the box and replaced the upper and lower bearings, I found grease had stopped/plugged oil/lubricants from the sector bushings. I use 600w oil that the supplier supply and the gear box turns easily. I haven’t seen oil leaking from the box, but haven’t really looked, at least not dripping on the floor. I don’t think the steering box gets hot enough for the corn head grease to flow, no flowing no lubricating
11-10-2023, 08:18 AM | #10 |
Use the end plate or nut, depending on 2-tooth or 7-tooth, that has the tube attached. The tube extends beyond the top level of the oil. That will stop the oil leaks. Use 85W-140 G5 in the gearbox. That oil will reduce the wear and provide low turning resistance in the box.
