Old 05-27-2018, 07:00 PM   #1
Nelson C
Default Hole Size & Location on 1931 Running Board Shield for a Well Fender
Is there a template or information regarding the Hole Size & Location on a 1931 Running Board Shield for the Well Fender Arm to fit through?
Also, do you have any suggestions/advice from prior experience?
The prior owner has had a well installed in the front fender, but the running board shield does not have a hole for the arm.
Thank you.
Nelson C is offline   Reply With Quote
Old 05-27-2018, 08:40 PM   #2
Don Turley
Don Turley's Avatar
Default Re: Hole Size & Location on 1931 Running Board Shield for a Well Fender
I have the instructions for making and using a locating tool for side mount holes in an album on my FordBarn page. Here is the link.
https://www.fordbarn.com/forum/album...ictureid=20356
Don Turley is offline   Reply With Quote
Old 05-27-2018, 11:05 PM   #3
Brentwood Bob
I remember reading that the hole locations for riveting the spare tire bracket on the frame are stamped on the frame. Take a close look. I may be more right than wrong
Brentwood Bob is offline   Reply With Quote
Old 05-28-2018, 04:40 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Bob,
Minerva had NO side mounts, but a hole in the forward part of the running board shield had been welded SHUT! She was an Early '30 Std. Coupe.
Bill Williamson
"THE ASSISTANT GURU OF STUFF"
Old 05-28-2018, 11:26 AM   #5
Brentwood Bob
Bill, key word is early 30 car. Keep the line moving.
I thought I saw a picture of the indents for locating the bracket on the frame.
Old 05-28-2018, 12:27 PM   #6
Flathead
Flathead's Avatar
I have the hole in pass side shield but no well in the fender. Funny how parts get swapped around over the years. I would give you the hole as I don't need it, but not that easy.
Flathead is offline   Reply With Quote
