Old 08-10-2015, 09:53 AM   #1
Tim Brown
Tim Brown's Avatar
Default Help... Looking for a EV8 u joint - Kingman Az
I am traveling in the 34 roadster. Currently at a buddy's in Kingman Az. I have a failing u joint that I need to ( or should) replace. Anyone out there have one handy...? Thx Tim 530 320-3604
Tim Brown is offline   Reply With Quote
Old 08-10-2015, 09:56 AM   #2
Tim Brown
Tim Brown's Avatar
Default Re: Help... Looking for a EV8 u joint - Kingman Az
Forgot to mention, I'm 650 miles from home. Thanks for looking.
Old 08-10-2015, 10:00 AM   #3
nospartsman
There is a long time Ford NOS parts dealer in Kingman Az his name is Bob Sweet he is on old 66 sorry I don't have his phone # he would have what you need.
nospartsman is offline   Reply With Quote
Old 08-10-2015, 10:05 AM   #4
34billct
34billct's Avatar
Bob Sweet 928 692 6656
34billct is offline   Reply With Quote
Old 08-10-2015, 10:18 AM   #5
Tim Brown
Tim Brown's Avatar
I've left a message for Bob. I'm hopeful that he can help with parts.
Old 08-10-2015, 10:38 AM   #6
nospartsman
When you find Bob Sweet ask to see his old 60's drag race photos from Ohio, he ran a Topolino. Bobs 84 and was a swap vendor at LA Roadster show this year, it's in his blood.
Old 08-10-2015, 10:59 AM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
Tim, I could send you a very good, but slightly used, USA made "U" joint. I buy a good number of top and side load EFV-8 transmissions, and many of them have good used "U" joints attached. If you are interested, send me a Fordbarn PM or Email.
John
Old 08-10-2015, 11:45 AM   #8
rheltzel
rheltzel's Avatar
Likewise, Tim, I have an NOS one I could overnight to you if you can't find one locally. I've PM'd you with contact details.
rheltzel is offline   Reply With Quote
Old 08-10-2015, 12:59 PM   #9
Chris
Chris's Avatar
Tim, if you can get it to the hill climb as-is I can bring one if needed
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 08-10-2015, 01:35 PM   #10
Tim Brown
Tim Brown's Avatar
Thanks for all the help. I was able to get a NOS part from Bob Sweet. Great guy and only 6 miles from me...
Old 08-10-2015, 02:28 PM   #11
JSeery
JSeery's Avatar
What a deal, the Barn at it's best!
Old 08-10-2015, 04:27 PM   #12
David J
David J's Avatar
Hey Tim , Curious about what lube and amount you had in the u-joint cavity ? Any pics as it was when first disassembled ? Thanks David J
David J is offline   Reply With Quote
Old 08-10-2015, 07:24 PM   #13
Tim Brown
Tim Brown's Avatar
No pictures. The u joint started to rub on the inside of the clamshell cover. It was just noise, but not knowing what it was, I wanted to fix it while we has access to a garage full of good tools. It's all back together now I just need to check fluid levels in the diff and trans.
Thanks again to you guys and Fordbarn for the quick parts locating services. One more flathead on the road again!
Old 08-10-2015, 07:28 PM   #14
rheltzel
rheltzel's Avatar
Fast work, Tim! Hope the rest of your drive to the Georgetown Hill Climb goes smoothly!
Old 08-10-2015, 08:50 PM   #15
JM 35 Sedan
How did you lube the U joint as it was going back together and what lube did you use? Just curious.
John
Old 08-11-2015, 11:04 AM   #16
34billct
34billct's Avatar
Join the EARLY FORD V8 CLUB OF AMERICA and you will get a Roster of Thousands Members willing to help you out. I never go any place with out it. Better than A--.
