Old 12-04-2019, 04:50 PM   #1
ahshoe
Default PVC hose destination
I have 390 in my '61 Galaxie that I am doing a restoration on. I have a twist on oil breather on the LH front area valve cover. In my RH rear grommet I have the PCV valve. Now my question is do I run the hose from the top of the PCV to the carb base OR the underside of the air cleaner? (which I have been doing on a few of my last restorations. Does it make a difference? Which, if any, is better?
ahshoe is offline   Reply With Quote
Old 12-04-2019, 05:09 PM   #2
darrell
Default Re: PVC hose destination
carb base.you must have a newer 390.
darrell is offline   Reply With Quote
