Old 04-04-2014, 08:18 PM   #1
cohammer60
cohammer60's Avatar
Default help please
Just a few more parts , these are ford pistons that was told were for a model but just not sure.
cohammer60 is offline   Reply With Quote
Old 04-04-2014, 08:28 PM   #2
Hicktick
Hicktick's Avatar
Default Re: help please
I see a piston box , you got hoodwinked .
I don't see anything that is model a .
Hicktick is offline   Reply With Quote
Old 04-04-2014, 08:40 PM   #3
cohammer60
cohammer60's Avatar
There are 11 boxes of pistons with pistons marked ford on them but I can't find those numbers on the box online anywhere.
Old 04-04-2014, 08:46 PM   #4
barnstuf
The 01T piston is 1935-42 era, the cylinder heads are also V8 flathead 1939-48 era and also the intake manifold is V8.
barnstuf is offline   Reply With Quote
Old 04-04-2014, 08:55 PM   #5
Charlie Stephens
The heads have 21 studs with a water outlet in the center so they are 1937-38.
Charlie Stephens
Old 04-04-2014, 09:08 PM   #6
SeaSlugs
SeaSlugs's Avatar
that "american bosh" distributor also has the Essex logo on it. id believe that to be off an essex car... I could be completely wrong tho...
the gauge says at the bottom "revs per minute in hundreds" so its an early tachometer for what i dont know.
strange to me to see engine miles and the standard number drum on a tachometer. and why they would label it engine miles. could this be off a stationary generator/engine of some sort? Kind of keeping to a standard of if a car needs lubed every 500 miles so does this and this is the equivalent "miles" its been ran. Much like today on small engines and stationary engines/generators we use an hour meter to regulate when to do service.
Also im not sure why else there would be 2 red lines that id assume would be where you want to keep the needle for optimal HP/torque.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-04-2014, 09:18 PM   #7
Bob C
The rods are Chevy 18G = 837107 33-E34, 18M = 838389 37-47,
18F = 836601 32 6cyl.
Bob
Old 04-04-2014, 09:26 PM   #8
Tinker
Tinker's Avatar
Cool sw tach... At least i think it is a tach...? Ya didnt hit the lotto but dont trash any of it.
Old 04-04-2014, 09:45 PM   #9
cohammer60
cohammer60's Avatar
I did get a lot of part and want bore you with much more but you never know if you don't ask.
Old 04-05-2014, 07:33 AM   #10
SeaSlugs
SeaSlugs's Avatar
nah your not boring us, most of us like all eras of cars and love to see old parts!
Old 04-05-2014, 09:18 AM   #11
mshmodela
mshmodela's Avatar
Those heads do not appears to be Model A heads.... ? Flat head V8 heads or ?
mshmodela is offline   Reply With Quote
Old 04-05-2014, 09:12 PM   #12
cohammer60
cohammer60's Avatar
Thanks for all the help.
