Old 04-08-2020, 10:57 AM   #1
jerry shook
Default Hard to start.
51 ford truck. Cranks easy when cold altering driving an turn it off after 10 min it just turns a lot before starting. It has an electrionic chip. Do I need to adjust carb.
jerry shook is offline   Reply With Quote
Old 04-08-2020, 11:29 AM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Hard to start.
A very well tuned and efficiently working ignition system is a must. All components of the ignition system need to function 100% to eliminate hard starts, from my experience. I run a traditional points system, Skip Haney rebuilt coil, new wiring also. My distributors have been set up on a Sun machine by both Bubba and Michael Driskell at Third Gen Automotive.
Old 04-08-2020, 11:30 AM   #3
corvette8n
corvette8n's Avatar
Does it have a coil, when they get hot they can fail.
You need to trouble shoot before you go adjusting stuff.
Pick one either fuel,spark,compression, and trouble shoot each until you find the problem.
Old 04-08-2020, 11:44 AM   #4
Mart
Mart's Avatar
Sounds like the carb is over rich for some reason.
By cranks easy I suppose you mean starts easy.
Try slowly opening the throttle before trying to start. slowly enough so you don't pump even more gas down there.
Mart.
Old 04-08-2020, 12:26 PM   #5
G.M.
Can't help you when chips are installed. Stock is nice. G.M.
www.fordcollector.com
Old 04-08-2020, 02:58 PM   #6
FlatheadTed
FlatheadTed's Avatar
The wrong resistance coil to match the Module ,may need a ballast , is it 12 volt
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-08-2020, 03:46 PM   #7
jerry shook
It is still 6 volt. I put the coil that is suggested for the electronic chip. Starts an runs great when cold an when you stop for 5 min just touch the button an it fires right up. but if you are 15 min it turns a lot before starting. Then it runs great. I have moved timing an adjusted carbutor still the same.
Old 04-08-2020, 03:54 PM   #8
Mart
Mart's Avatar
Does it fire up better if you open the throttle?
Old 04-08-2020, 05:18 PM   #9
jerry shook
It is the same if you give it gas easy or continue to give it gas. Still spines a lot before starting.
Old 04-08-2020, 05:28 PM   #10
FlatheadTed
Jerry Tyi a little gas down the carb ,see if its drain back, OK not that ,does it puff smoke out the pipe when finial fires
Old 04-08-2020, 07:09 PM   #11
drolston
drolston's Avatar
I presume you are running Pertronix ignition, which has a good reputation on 12 volts and has been very reliable on my 12 volt flathead. But Pertronix has a less reliable record on the 6 volt version. Solid state electronics get flakey if they get too hot. So starting and running with the distributor directly in the fan breeze may keep the 6 volt unit running fine. But sit for a while with no cooling and the engine heat transfers to the distributor to the point that the ignition fails. Just a theory!
This theory can be tested. Run till the engine is hot. Shut down and immediately check the spark to see if it will jump half an inch with a blue spark. Then wait 15 minutes and check it again to see if the spark is weak, like yellow spark will barely jump a quarter inch. It that is the case, swap out the Pertronix to get a more reliable unit, or go back to points.
Old 04-08-2020, 07:23 PM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
That sounds similar to a problem I once had with excessive gas leak down from carburator into intake manifold caused by a faulty power valve, or PV seal.
John
Old 04-11-2020, 08:45 AM   #13
Brendan
Brendan's Avatar
get rid of the electronic stuff
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 04-11-2020, 10:26 AM   #14
tubman
tubman's Avatar
From everything I have seen and heard, aftermarket electronic ignition systems have caused more problems than they have solved.
Old 04-16-2020, 03:36 AM   #15
Karl
Karl's Avatar
Agreed .The more I go on the more I realize that most modern improvements aren't improvements at all !
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
