06-03-2019, 07:31 PM | #1 |
1936 coupe/ sedan rear body mounts
Under the trunk floor is a channel cross member that bolts to the chassis at each end. I have the squashed remains of 2 wooden blocks, that are meant to fit between the channel and the chassis.
Can anyone help me with the original dimensions of this please? |
06-04-2019, 05:27 PM | #2 |
Re: 1936 coupe/ sedan rear body mounts
Was a thread a couple of years ago with pictures and dimensions but I haven't been able to find it. I'm pretty sure I have at least some of the info saved on a computer also and will try to find and post if nobody else offers anything first.
06-04-2019, 09:04 PM | #3 |
Thanks Randy, appreciate your help, I tried searching too, but you have to get the question right too...
06-05-2019, 10:26 AM | #4 |
The wood blocks on my 35 coupe measure inch and 3/4 by inch and 1/2 x 2 1/2“ long The left one is slightly longer than the right one so I don’t think the length is as critical it just provides a cushion for the body mount.
06-05-2019, 10:46 AM | #5 |
I have two 35 Tudor sedans completely apart. I think those wooden pieces are still attached to that cross channel. I can take a look at them today, try to get dimensions and pics if possible. I may have been the one who posted info on these here some years ago, but CRS now.
06-05-2019, 09:58 PM | #6 |
06-05-2019, 10:31 PM | #7 |
That is great, thank you, it confirms that the better block that I have is still very squashed ant it looks as if the block should stick out of the channel by about 1/8"
06-06-2019, 05:58 AM | #8 |
Yes indeed, both blocks protrude below the bottom channel by an 1/8” or so.
