Old 06-03-2019, 07:31 PM   #1
kustoman
Default 1936 coupe/ sedan rear body mounts
Under the trunk floor is a channel cross member that bolts to the chassis at each end. I have the squashed remains of 2 wooden blocks, that are meant to fit between the channel and the chassis.
Can anyone help me with the original dimensions of this please?
kustoman is offline   Reply With Quote
Old 06-04-2019, 05:27 PM   #2
Randy in ca
Randy in ca's Avatar
Default Re: 1936 coupe/ sedan rear body mounts
Was a thread a couple of years ago with pictures and dimensions but I haven't been able to find it. I'm pretty sure I have at least some of the info saved on a computer also and will try to find and post if nobody else offers anything first.
Randy in ca is offline   Reply With Quote
Old 06-04-2019, 09:04 PM   #3
kustoman
Thanks Randy, appreciate your help, I tried searching too, but you have to get the question right too...
Old 06-05-2019, 10:26 AM   #4
RalphM
RalphM's Avatar
The wood blocks on my 35 coupe measure inch and 3/4 by inch and 1/2 x 2 1/2“ long The left one is slightly longer than the right one so I don’t think the length is as critical it just provides a cushion for the body mount.
File Type: jpg 116DAD53-D4C5-4BF7-8C42-CEEFC7E5B715.jpg (34.0 KB, 36 views)
RalphM is offline   Reply With Quote
Old 06-05-2019, 10:46 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
I have two 35 Tudor sedans completely apart. I think those wooden pieces are still attached to that cross channel. I can take a look at them today, try to get dimensions and pics if possible. I may have been the one who posted info on these here some years ago, but CRS now.
John
Old 06-05-2019, 09:58 PM   #6
50droptop
Here are some photos I snapped of a 36 5W I’m working on.
50droptop is offline   Reply With Quote
Old 06-05-2019, 10:31 PM   #7
kustoman
That is great, thank you, it confirms that the better block that I have is still very squashed ant it looks as if the block should stick out of the channel by about 1/8"
Old 06-06-2019, 05:58 AM   #8
50droptop
Yes indeed, both blocks protrude below the bottom channel by an 1/8” or so.
