04-22-2013, 10:24 PM | #1 |
A simple wiring question!
With the key in the off position is the coil hot on both sides?
04-22-2013, 10:38 PM | #2 |
Re: A simple wiring question!
With stock Model A wiring, yes.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
04-22-2013, 10:53 PM | #3 |
04-23-2013, 11:24 AM | #4 |
the way i see it if it is your going to have a dead battery soon, and if some one wants to steal the car all they would have to do is push start it
04-23-2013, 11:30 AM | #5 | |
No dead battery and no car being stolen. |
04-23-2013, 11:57 AM | #6 |
This is why it is a good idea to install a fuse holder on top of the starter. Remove the fuse when securing the car for the day and it will remove power from all these locations. Tom Endy |
04-23-2013, 12:06 PM | #7 |
Ford did many things "unconventional."
I used to get people in the shop that replaced starter relay/solenoids with later style "typical ones." That is the push button energizes the relay windings and pulls down the contactor. Ford tied the windings to one of the big posts marked battery, to energize the relay you grounded the winding thru' the push button. In charging systems he used B circuits almost exclusively, he deviated rarely. Delco almost always used A circuits. Dodge used both!
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
04-23-2013, 12:07 PM | #8 | |
What are A and B circuits? |
04-23-2013, 12:38 PM | #9 |
A circuit field tied to voltage source inside generator and regulator
switches resistance in and out of circuit to ground to control field current. Grounding field terminal produced full output. B circuit field is grounded inside generator and regulator switches resistance between field terminal and voltage source to control field current. |
04-23-2013, 09:00 PM | #10 |
Ok just to clarify, some of the answers are a bit confusing. The black side of the coil is hot at all times. You will get a voltage reading to ground on the red side of the coil with switch off and points open. This is feeding through the coil. If you disconnect the red wire from the coil, the coil terminal will have voltage to ground the red wire will not. The red wire furnishes a ground to the coil via the key switch when the points close. This is what causes the coil to fire each time the points close.
