06-29-2015, 11:01 PM | #1 |
Any good ways to put holes in frame webbing?
Getting ready to put the holes in my webbing and I remember on my last car it was a BEAR. Anyone have a good technique they are willing to share?
Thanks in advance. Z |
06-29-2015, 11:06 PM | #2 |
Re: Any good ways to put holes in frame webbing?
I bought an inexpensive hole punch from Ace hardware. Other sources: Tandy Leather, Fastenall.
Tim Downtown, Ca |
06-30-2015, 12:07 AM | #3 |
As Tim mentioned, a hole punch works great. Make sure it's sharp
06-30-2015, 12:26 AM | #4 |
Cheap Harbor Freight set of hole punches and a block of hardwood to punch on.
06-30-2015, 07:31 AM | #5 |
What they said. Hardwood is important.
06-30-2015, 07:41 AM | #6 |
06-30-2015, 08:51 AM | #7 |
I remember using a ball peen hammer on it right on the frame, as I was installing it. It worked !
MIKE (mikeburch) |
06-30-2015, 08:52 AM | #8 |
Vice grips on a small section of 1/2 inch copper works well.I heat the pipe up with a propane torch and burn a nice clean hole through the webbing.
06-30-2015, 11:28 AM | #9 |
stretch the webbing out on the frame and secure the ends, take a piece of chalk and find the holes and mark them with a piece of chalk, while the webbing is still on the frame slip a piece of hard wood under webbing and punch the holes right there, that way you can correct any that might get off, use a slightly bigger punch to get some play to make it easier to install the bolts
06-30-2015, 11:33 AM | #10 |
maybe im wrong, but shouldn't this post be in the model a room?
06-30-2015, 12:24 PM | #11 |
Any frame needing webbing will do here.
06-30-2015, 01:47 PM | #12 |
franklin your right, but I just related webbing to the model a's
06-30-2015, 02:25 PM | #13 |
Usually everyone has a bunch of extra brass hose barbs that come in kits in various sizes. Which I personally don't throw away.
Some wood, a hammer, and a couple hose barbs. Most likely all these things you might already have stashed in your garage. Works really well when making gaskets too. |
06-30-2015, 02:34 PM | #14 |
06-30-2015, 02:35 PM | #15 |
Ford used it at least through the '38 model year.
06-30-2015, 03:21 PM | #16 |
Question, how do you tell model a webbing from efv8 webbing? :-)
Tim Downtown, Ca |
06-30-2015, 06:06 PM | #17 |
A hole punch works great.
The sign of a good craftsman is how well they cover up their mistakes. |
06-30-2015, 07:16 PM | #18 |
I recommend Willit Stop's technique
