Old 09-22-2015, 08:23 PM   #1
loubob
Default Tillotson Carb Idle
Earlier today I "rebuilt" a Tilly 'X' carb.
Installed on car and started it up.
From start up thru warm up, and after, I could not adjust the semi fast idle down at all.
All parts are connected properly.
Retarding spark all the way caused idle to slow and car started to stall out.
Suggestions/recommendations requested. Thanks!
Loubob
loubob is offline   Reply With Quote
Old 09-22-2015, 08:44 PM   #2
rob63mess
rob63mess's Avatar
Default Re: Tillotson Carb Idle
Sounds like the float level may not be adjusted correctly.
rob63mess is offline   Reply With Quote
Old 09-22-2015, 09:14 PM   #3
Mitch//pa
just a guess is it possible the throttle plate could be on upside down... on many carbs they are chamfered..
do you have the base idle screw backed all the way out? try disconnecting the throttle linkage also??
vacuum leak...
Old 09-22-2015, 09:21 PM   #4
Dick Deegan
Dick Deegan's Avatar
My bet would be the throttle plate.
Dick Deegan is offline   Reply With Quote
Old 09-22-2015, 09:24 PM   #5
mrtexas
mrtexas's Avatar
vacuum leak...
Not on a Tilly
mrtexas is offline   Reply With Quote
Old 09-22-2015, 09:25 PM   #6
mrtexas
mrtexas's Avatar
Loubob
What do you mean by rebuilt? Did you take out all the plugs and make sure the passages weren't plugged? Idle passages are small.
https://sites.google.com/site/mrtexa...ly-carburetors
Old 09-22-2015, 09:28 PM   #7
Mitch//pa
Originally Posted by mrtexas View Post
Not on a Tilly
Okay thanks for the info,, I never had the opportunity to rebuild one yet...
Old 09-22-2015, 11:10 PM   #8
mrtexas
mrtexas's Avatar
They are much easier to rebuild than a zenith.
Old 09-23-2015, 01:49 AM   #9
burner31
burner31's Avatar
Love my Tilly, works great.
Did it do any of that before the re-build?
Take it off, take it apart, take your time.
Clean every passage, adjust the float, and put it back together slowly.
Back the GAV out 1/2 way "before" you seat it.
Keith
Shawnee OK
'31 SW 160-B
Old 09-23-2015, 06:30 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Back off the idle speed screw, and make sure the throttle plate closes completely. If it doesn't, then loosen the two plate screws and shift the plate and shaft so the plate is fully closed, then tighten the screws.
Old 09-23-2015, 09:30 PM   #11
loubob
I did not remove the plugs.
Disassembled as much as possible.
Soaked all in carb cleaner.
Cleaned parts and either replaced or reinstalled.
I'm quite sure I installed new main jet. They are a bear to remove.
I think I bought it as a "rebuilt."
I will redo as suggested next week.
Today I built another, from 2, and it runs great......so far.
I will give update soon.
Thank you as always!
Loubob
Old 09-24-2015, 11:15 AM   #12
Redbird
Redbird's Avatar
Since all passageways have an in & out side, make sure to blowcompressed air both ways to clean out.
Redbird is offline   Reply With Quote
Old 09-24-2015, 12:34 PM   #13
Patrick L.
Patrick L.'s Avatar
What Tom W says and there are 2 air bleeds in the venturi that need to be really really clean.
Old 09-24-2015, 12:53 PM   #14
hewe
Interesting thread. I am looking for specs on the jets. Any help would be appreciated.
I have a couple I would like to rebuild.
hewe is offline   Reply With Quote
Old 09-24-2015, 06:07 PM   #15
Tom Wesenberg
Steve Pargetter has a great booklet on rebuilding carbs. Not too much money, and well worth having even if you don't have a carb to do.
Old 09-24-2015, 07:31 PM   #16
mrtexas
mrtexas's Avatar
No specs on the jets like a zenith. Only trick is to take out the 3 lead plugs and one welch plug to clear out passages. Main jet can be difficult to remove about half the time.
