01-13-2015, 02:06 PM | #1 |
36-41 Rear spring bolts to cross member fit??????
I am putting the rear spring into the crossmember and when I tighten the nuts onto the u-bolt the braces/brackets/keepers are tight to the spring but they are not being pushed up tight to the cross member. Is this correct? I thought the nuts and lock washers would push the cross piece from the u-bolt against the spring and the eyelets would be up against the cross member?
As Always, thank you for any advice. Z |
01-13-2015, 02:47 PM | #2 |
Re: 36-41 Rear spring bolts to cross member fit??????
Here's what the U-Bolts and clamps look like on my 1940 Ford car. These are the original stock 1940 Ford parts. I did not use washers.
Nuts are torqued to 80 foot pounds. Are you sure you have the correct parts? The U-bolt clamps should go on quite easily - a little at a time. Last edited by 19Fordy; 01-13-2015 at 02:54 PM. |
01-13-2015, 03:04 PM | #3 | |
01-13-2015, 07:50 PM | #4 |
Thanks for the pic and quick response. That is what mine looks like I just thought when I took it apart the eyelets were up to the bottom of the cross member. I guess that is what happens when a quick "over the winter" rebuild ends up taking 3 yrs.
Thanks Z |
01-14-2015, 06:46 AM | #5 |
The spring should go all the way into the cross member and bottom out (there should be a piece of fiber anti-squeak material between the spring and cross member). There may be a square head bolt in the center of the spring (the square head bolt fits into a square hole in the anti-squeak material. The square portion of the bolt has to fit (through the anti-squeak and also ) into a square hole in the top of the cross member.
Do you have the correct amount of spring leafs? any missing and you MAY have to add a filler to the bottom of the spring or you could run out of threads on the U-bolts and the nuts will bottom out. Last edited by Terry,OH; 01-14-2015 at 08:02 AM. |
01-14-2015, 07:12 AM | #6 |
Mart. |
