Old 09-04-2016, 04:06 AM   #1
darcarter
Default Wrong Nails?
I'm having a very difficult time nailing the sheet metal onto new wood. I'm using 3d 1 1/8" nails and am bending 6 or 7 nails for every one I am able to get in straight. Is there a better nail?
darcarter is offline   Reply With Quote
Old 09-04-2016, 05:45 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Wrong Nails?
See if you can find 'body nails'. They are about 1 inch long and are corrugated. About the diameter of a small finishing nail.
29spcoupe is offline   Reply With Quote
Old 09-04-2016, 05:49 AM   #3
Jack Innes
Jack Innes's Avatar
Mac's sells nails made for the job;
http://www.macsautoparts.com/ford_mo...ody-nails.html
You may still have to drill pilot holes if you are dealing with dry oak.
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 09-04-2016, 08:46 AM   #4
15max
I used lath nails in Oak. Drilling holes was necessary. Holding the nails with pliers part way in helped. Yes there are better nails but these were cheap and so am I. Hope you find a good solution. The Tudor is looking good.
15max is offline   Reply With Quote
Old 09-04-2016, 10:57 AM   #5
tmodelman
tmodelman's Avatar
Bronze boat nails. They are ringed and won't ever rust and are tough.
Get at any hardware, or Wallymart.
tmodelman is offline   Reply With Quote
Old 09-08-2016, 04:54 AM   #6
darcarter
Outstanding. Thanks. I thought there might be a better solution.
