07-18-2017, 09:38 AM | #1 |
engine removal
Has anyone removed the engine by removing the bolts in the clutch housing & leave the flywheel housing on the block? I'm getting lazy as I get older & don't want to remove the tranny if I don't have to. Thanks.
07-18-2017, 09:43 AM | #2 | |
Re: engine removal
To answer your question, I have never done it that way but I have seen others remove just the engine. Good Luck. Last edited by Y-Blockhead; 07-18-2017 at 10:20 AM. |
07-18-2017, 10:05 AM | #3 |
Re: engine removal
I tell ya, do it now, or do it later. Removing the engine and trans together is sooo much easier than separately, but if you just pull the engine, you will find that out when you go to reinstall it. Besides, it is also the perfect time to check that U-joint.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! Last edited by RawhideKid; 07-18-2017 at 10:06 AM. Reason: too many words |
07-18-2017, 10:09 AM | #4 |
Re: engine removal
I remove engines all the time by removing the bolts between the bellhousing and the flywheel housing. I find it easier to put back in rather than joining up the u-joint. When re-installing, place two tapered 3/8" bolts (cut the head off a 3/8 x 3" bolt and grind the cut off side to a taper) in the flywheel housing just below each rear engine mount. The tapered bolt will aid lining everything up as it comes together. After the parts are together, install a couple of the 3/8" bolts in open holes and then remove your tapered bolts. Save the tapered bolts for the next time you need them.
07-18-2017, 10:11 AM | #5 |
Re: engine removal
When I put my engine in early this year, I left the transmission in place. I placed a "rachet strap" around the top of the car and then down around the transmission. This worked pretty good to help align the trans input shaft into the clutch.
07-18-2017, 10:13 AM | #6 |
Re: engine removal
07-18-2017, 12:07 PM | #7 |
Re: engine removal
I like your idea Dave. I just need to come up with a way to hold the tranny. Do you have much trouble lining up the clutch plate to the output shaft of the tranny?
07-18-2017, 02:26 PM | #8 | |
Re: engine removal
I also agree with and practice what Dave has advised, because it makes 'things' easier, if the engine is all that you want to deal with. I use blocks and / or hydraulic jack under trans to easily manage its position. If you have help, one way to easily engage trans shaft into clutch disc gear, is to jack rear wheels off of floor (jack stands can be used to do this when starting/preparing to remove engine) . With rear wheels off of floor, you/or helper can slightly move rear wheel , which will move trans gear and I've used this to easily engage those gears. I've found that lifting car and placing on jack stands makes my job easier, because the car sits tooo low for me to do any crawling around under it. Being stabbed by any/all of the cotter pins that ford buy in this car is not fun, IMO. |
07-18-2017, 04:08 PM | #9 | |
Re: engine removal
Good Day! |
07-18-2017, 07:37 PM | #10 |
Re: engine removal
Lining up the clutch disk splines with the input shaft splines can be difficult. Prior to engine installation I use some white typing correction fluid to mark the tips of 3 consecutive high splines on the input shaft and 3 consecutive marks on the clutch disk at the belly of the spline. It makes it easy to see when the clutch disk splines and the input shaft splines are lined up. You will be able to reach through the inspection hole in the clutch housing and turn the input shaft to line them up when the transmission is in neutral. I also use a slight spot of grease on the clutch splines for easy meshing of the splines. I have installed my engine by myself several times and used a floor jack to put the transmission in line with the engine. JMO
07-18-2017, 08:54 PM | #11 |
Re: engine removal
If you had a multi disc clutch would it change how you pull and reinstall the engine
07-18-2017, 10:19 PM | #12 |
Re: engine removal
07-19-2017, 06:45 AM | #13 |
Re: engine removal
I always leave the transmission in the car, unless it needs work. To line up the trans spline, just jack up one wheel. then turn it easy. you can feel it in gauge.
I use bolts with the heads cut off in the clutch housing and a jack under the trans. It is a pice of cake to get it in this way. |
07-19-2017, 06:58 AM | #14 |
Re: engine removal
Yup, all the time.
07-19-2017, 07:07 AM | #15 |
Re: engine removal
I always leave the gearbox in the car and have no trouble lining things up again when the motor goes back in and I work alone.
07-19-2017, 07:40 AM | #16 |
Re: engine removal
Yes! I did! See my album "My Coupe" (red wheels) There a few pics of it.
Terry |
07-19-2017, 07:53 AM | #17 |
Re: engine removal
I like pulling engine by itself, I pull the water pump off and leave the head light bar on. I also put two 3/8" X 3" studs that I sharpen the ends on in the flywheel housing when installing the engine to help line up
