05-21-2013, 04:21 PM | #21 |
Re: Speedo Cable Issues
Bill I was looking at the speedo and was wondering how do you get that plug out. Does it screw in or is it just pushed in?
05-21-2013, 05:37 PM | #22 |
It is pushed in and staked.
Use a stanley knife and cut/scrape the edge of the stake burr away a bit and get the sharp point of the knife in and under and carefully pry it out. |
05-21-2013, 05:49 PM | #23 |
After removing the burr with a knife, I tapped one side of the disc and it tilted up on the other end.
05-21-2013, 06:01 PM | #24 |
Tom, I drilled a 3/32" hole in the edge closest to where the cable attaches, there's solid metal under there. When the bit went through, the plug just "twirled" up my bit! I tole you all I wuz GOOD! Bill W.
05-21-2013, 06:13 PM | #25 | |
05-21-2013, 06:37 PM | #26 |
05-21-2013, 08:50 PM | #27 | |
So in there is where old grease could be that can jam it up?
1929 Model A Ford Coupe |
05-21-2013, 11:08 PM | #28 | |
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 05-21-2013 at 11:19 PM. |
05-22-2013, 07:01 AM | #29 |
Mine didn't have one, it wasn't in a bag when I got it.
1929 Model A Barn find. California car, just a few more parts to find. Interior, steering box (rebuild), and I am sure much more! |
