Old 12-01-2015, 09:55 PM   #1
CSArno
CSArno's Avatar
Question good places for glass for 49 F1?
anyone have a good source for glass? need a drivers side vent window and passenger side door glass.
thanks.
CSArno is offline   Reply With Quote
Old 12-01-2015, 09:58 PM   #2
billwill
Default Re: good places for glass for 49 F1?
Most times precut glass must be recut.best to buy at a glass vender I know better lock
billwill is offline   Reply With Quote
Old 12-01-2015, 10:00 PM   #3
billwill
Half ton Fun in new jersey glass in stock. better luck.
Old 12-01-2015, 10:43 PM   #4
RalphM
RalphM's Avatar
It's all flat glass, make a pattern and have it cut.
RalphM is offline   Reply With Quote
Old 12-01-2015, 11:14 PM   #5
Ross F-1
Ross F-1's Avatar
I've gotten it both ways. Locally cut glass was not as good a fit as LMC's. Cost the same too. LMC's is made in Taiwan, but very well made.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 12-02-2015, 04:36 AM   #6
moefuzz
moefuzz's Avatar
Ralph is on the ball,
This isn't offshore rocket science.
Correct -To Spec- Laminated Safety Glass is Still being made in the USA.
...Use your existing otherside/opposite windows for pattern and take them to your local glass shop.
They should not be more than about $10 or $15 per square foot Cut to Size from American spec glass. I did 8 windows in my '41 Business coupe for far less than $200.
If your glazzier says $$$$.$$
tell him to go to Japan where the internal anti shatter/safety film inherent in safety glass is ultra thin
and/or made of water soluble based polymers that disintegrate and/or are very poorly bonded
from day one (Asia has no use for SAE or Safety specs)
If your local glass shop wants more that ~$15 per sq foot (cut to size),
Call around or Go to the shop across town and/or until you find an honest glazzier that cuts glass to size for the actual going rate. $15/foot (no postage required)
Automotive (Laminated) Safety Glass is not expensive in the USA..
-and when supplied by/inside the USA, it is to USA/SAE spec as per 1947 or 37
SAE standards Still To This Day.
-Which means it isn't prone to premature separation/Delamination due to the fact that it doesn't contain ultra thin water based polymer? which is not actually a polymer and Is Certainly
Not To 1947 or 1937 USA/SAE spec to this day..
For what its worth,
Fukk offshore
?When will it be time for Americans to Support their neighbors kid's job?
?Instead of supporting someone who could care less if your throat was cut by sh*t thin glass
and/or may be selling profitable electronics/arms to the newest emigrant on the next block.
-Not that there's anything wrong with that.
moefuzz is offline   Reply With Quote
Old 12-02-2015, 04:59 AM   #7
Ken Crans
Ken Crans's Avatar
If you want quality, I got all my glass from Sacramento Vintage Ford in Cali. Most people think its a standard 1/4 inch,but isn't. Its .239 thick to slide in channel and between the fuzzies. 1/4 is too thick, binds up when rolling up and down.
Ken Crans is offline   Reply With Quote
Old 12-02-2015, 07:24 AM   #8
fourfords
fourfords's Avatar
I like Sanders glass. http://sandersreproglass.com/order.htm
fourfords is offline   Reply With Quote
Old 12-02-2015, 07:55 AM   #9
FortyNiner
FortyNiner's Avatar
Since the local guys may not do much automotive glass, they could actually order it out as well. Happened to me and cost was more than LMC or others. Gotta shop around, no different than any other buy.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 12-02-2015, 09:05 AM   #10
Gumpy
Gumpy's Avatar
Bobs glass in Oregon ,, no sales tax and he cuts it!
Do a search in the archives here it will have all the contact info,, good luck --- Gump
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
