Old 11-06-2020, 12:21 PM   #1
bpaupst
Default 1936 Ford Passenger Pickup Front Fenders
I'm looking for front fenders for a 1936 ford passenger pickup truck. I'm having trouble finding some steel ones from 1936. Does anyone know if there's an interchangeable parts catalogue showing if they used the same fenders on other vehicles or years of the pickup? I would like to assume maybe the 1935 ford passenger pickup is the same, but am not sure. Is there any other possibilities?
Thanks!
bpaupst is offline   Reply With Quote
Old 11-06-2020, 12:32 PM   #2
frnkeore
frnkeore's Avatar
Default Re: 1936 Ford Passenger Pickup Front Fenders
'35 - '37 should all fit.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 11-06-2020, 01:17 PM   #3
bpaupst
Thanks, Would the 1934 ford car fenders be the same as the 36 pickup? I know the grilles lagged behind two years, just not sure if they used the same fenders as well.
Old 11-06-2020, 01:31 PM   #4
Brian
Brian's Avatar
No, 34 totally different. Frank gave you the correct answer above
Old 11-06-2020, 07:40 PM   #5
TJ
TJ's Avatar
Pickup fenders are specific for pickups.
Old 11-06-2020, 08:17 PM   #6
Don Rogers
Don Rogers's Avatar
35 fenders have closed holes where the bumper brackets go through. 37 and 37 have an open hole.
Don Rogers is offline   Reply With Quote
Old 11-07-2020, 09:05 AM   #7
bpaupst
Great, so 36 or 37 is what I am looking for. I want the truck exterior to be correct to 36.
Thanks everyone!
Old 11-07-2020, 11:34 AM   #8
blucar
blucar's Avatar
Thanks everyone!
I think it has been stated to you before that you should drop/discontinue the phrase "Passenger Pickup..
The 35-and later Ford pickups are just pickups, except for the '38 and later Tonners.
You need '35-37 pickup fenders, front and rear with running boards. However, if you are building a 1/2 flat bed you will need the running boards for same.
In past years, over 30, I restored one 36 and two '37 Ford 1/2 ton pickups.
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
