Old 10-26-2020, 08:27 PM   #1
DaveBPT
Default thermostat
Working on a stock '35 Flathead. Sent leaking water pumps out to be rebuilt. Planning to replace radiator hoses and thermostats. The thermostats I've seen so for that match what CAME OUT OF THE CAR are listed for 1937 -40. Any suggestions?
Dave
DaveBPT is offline   Reply With Quote
Old 10-26-2020, 10:25 PM   #2
JSeery
JSeery's Avatar
Default Re: thermostat
Are you looking to use a barrel shaped thermostat, or a modern style one?
Old 10-27-2020, 07:59 AM   #3
G.M.
Look up [email protected] G.M.
www.fordcollector.com
Old 10-27-2020, 10:17 AM   #4
JSeery
JSeery's Avatar
I know nothing about these thermostats, never used them, but I know they exist.
Old 10-27-2020, 10:51 AM   #5
Seth Swoboda
Seth Swoboda's Avatar
I've used them. So far they work just fine.
Old 10-27-2020, 10:42 AM   #6
big job
big job's Avatar
what is a so called "modern thermostat" ?
big job is offline   Reply With Quote
Old 10-27-2020, 01:32 PM   #7
JSeery
JSeery's Avatar
That is what I would call the one you buy at the local autoparts store.
Old 10-27-2020, 01:19 PM   #8
DaveBPT
The ones that were in it are the barrel type. I'm guessing that I need them?
Old 10-27-2020, 01:30 PM   #9
JSeery
JSeery's Avatar
Depends on you and what you want to install.
Old 10-27-2020, 05:03 PM   #10
billybronco1
For me on my 36 is the question to run with or without thermostats? Mine is a bellows type that goes in the hose. What are the advantages and disadvantages to run without? Right now as far as I know I'm without, and another question is do I just put one in and on what side?
billybronco1 is offline   Reply With Quote
Old 10-27-2020, 06:15 PM   #11
petehoovie
petehoovie's Avatar
Two are required. One in each upper hose....
Old 10-27-2020, 05:47 PM   #12
JSeery
JSeery's Avatar
Thermostats bring the engine up to operating temperature quicker and maintain a minimum temperature. Higher engine temperatures improve lubrication, helps remove blowby contamination of the oil, reduce sludge build up, increase engine efficiency, etc. Lots of benefits.
Old 10-27-2020, 07:08 PM   #13
billybronco1
My car seems to run so hot all the time, no issue with it running cold. Temp gauge sits about 7/8 all the time while cruising.
Old 10-27-2020, 08:19 PM   #14
petehoovie
petehoovie's Avatar
Get yourself one of these > https://www.amazon.com/s?k=infrared+...f=nb_sb_noss_2
ThermoPro TP30 Digital Infrared Thermometer Gun Non Contact Laser Temperature Gun
Old 10-27-2020, 09:24 PM   #15
JSeery
JSeery's Avatar
Yep, need to check it with an IR gun to know what it is really reading. Thermostats should not have any impact on the maximum operating temperature.
Old 10-29-2020, 07:48 AM   #16
bmwillia
bmwillia's Avatar
I am running two 180 degree stats from Robert Shewman. I just got them last week and they are very nice and are working great so far.
One thing to mention when using a laser temp gun is to keep in mind that the internal temperature of the engine will be several degrees hotter than the external temps you read with the gun.
I am by no means an expert as all of these guys just helped me work through my own cooling issues, but while reading up on my issues I found that information on using the temp guns.
Brad Williamson
bmwillia is offline   Reply With Quote
Old 11-04-2020, 09:58 PM   #17
cajunfirehawk
cajunfirehawk's Avatar
Just saw an original ford set on ebay the other day, auction said they were rare?
https://www.ebay.com/itm/Ford-Flathe...2/114499336643
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 11-04-2020, 10:09 PM   #18
JSeery
JSeery's Avatar
I would guess they are rare and most likely worn out! Not sure why anyone would want to run them.
Old 11-04-2020, 10:12 PM   #19
cajunfirehawk
Thumbs up Re: thermostat
Auction says
2 Antique Vintage Ford in-hose thermostats.
Tested. Open at 145 degrees. Very rare.
YMMV, but I agree, I sent the gent listed above an email about his new t-stats, for $5o for the pair, I'd prefer peace of mind for new.
Regards,
Todd
Old 11-04-2020, 10:14 PM   #20
JSeery
JSeery's Avatar
Auction says
YMMV, but I agree, I sent the gent listed above an email about his new t-stats, fro $5o for the pair, I'd prefer peace of mind.
And who the hell would want 145 deg thermostats, LOL.
