12-03-2023, 07:42 AM | #21 |
Re: Engine Install
X 2 on the long bolts, when you work by yourself you need all the help you can ! Cut the heads off, grind a taper, cut a slot for a screwdriver for easy removal. Jet engine mechanics install protectors over the mounting bolts and then unscrew them.
12-03-2023, 09:59 AM | #22 |
Re: Engine Install
12-03-2023, 10:12 AM | #23 |
Re: Engine Install
12-03-2023, 11:44 AM | #24 |
Re: Engine Install
If you have taps and dies, get some solid rod at your local hardware store or metal supplier and thread about 1/2" of one end, then slot the other end with a cutoff wheel or hacksaw blade. Handy for mounting that 60 lb flywheel as well.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
12-04-2023, 08:09 AM | #25 |
Re: Engine Install
I shortened my engine leveler, and made the frame spreader. I had some threaded rod that I cut and ground for the alignment dowels. Splines are marked for visual aid to align transmission shaft.
If all goes well, I will be reinstalling the engine this weekend. Thank you everyone who has helped me get to this point. |
12-04-2023, 11:11 AM | #26 |
Re: Engine Install
12-04-2023, 11:16 AM | #27 | |
Re: Engine Install
FWIW I used this leveler and did not need to shorten it. |
12-04-2023, 11:27 AM | #28 | |
Re: Engine Install
12-04-2023, 07:07 PM | #29 |
Re: Engine Install
[QUOTE=alexiskai;2274297]I'm so proud, I think this is the first time someone has reproduced something I designed.
I can't wait to put it to use this weekend. Thank you for sharing your efforts. |
12-04-2023, 07:32 PM | #30 |
Re: Engine Install
In the first picture you have a fumaze. Hope you used it while the engine was being stored and not operated. Remove before starting the engine.
12-04-2023, 07:47 PM | #31 | |
Re: Engine Install
12-04-2023, 08:51 PM | #32 |
Re: Engine Install
12-05-2023, 06:07 PM | #33 |
Re: Engine Install
Sorry Fumaze is a breather on the oil fill tube. Take of the air filter on the carb. The car will run better without it.
