Old 08-14-2021, 12:28 PM   #1
al's28/33
al's28/33's Avatar
Default help with vibrating mirror !
My rear view mirror vibrates too much when driving at any speed. The bracket is mounted directly on the metal header over the front windshield, so would a felt pad work better or is a rubber gasket good enough to keep that darned mirror steady?
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 08-14-2021, 01:10 PM   #2
Big hammer
Default Re: help with vibrating mirror !
In your phaeton? Cork does a nice job for quieting down vibrations, if you don't squeeze it to much.
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 08-14-2021, 02:08 PM   #3
al's28/33
al's28/33's Avatar
not the phaeton, my 33 pickup in which I am using a modified bracket and mirror so I can see right thru the rear window. I could never locate the correct one and other mirror angles did not align up with the rear window.
Old 08-14-2021, 02:09 PM   #4
al's28/33
al's28/33's Avatar
Old 08-14-2021, 03:06 PM   #5
ronn
rubber grommets............
Old 08-14-2021, 11:06 PM   #6
CWPASADENA
CWPASADENA's Avatar
The 33 Pick-Up originally did not have an inside rear view mirror, only an outside mirror on the left side. You may try making the mirror bracket very stiff. Any springiness in the bracket will accentuate the vibration.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 08-15-2021, 05:57 AM   #7
nkaminar
nkaminar's Avatar
Does anyone else remember this: Many years ago there was an article about how to analyse the reflection in the vibrating rear view mirror to determine engine problems. If it was jumping up and down it was a rod bearing or side to side a main. I am pretty sure it was a spoof, more humor than fact.
Old 08-15-2021, 06:12 AM   #8
Patrick L.
Patrick L.'s Avatar
Originally Posted by nkaminar View Post
does anyone else remember this: Many years ago there was an article about how to analyse the reflection in the vibrating rear view mirror to determine engine problems. If it was jumping up and down it was a rod bearing or side to side a main. I am pretty sure it was a spoof, more humor than fact.
lol !
Old 08-15-2021, 09:39 AM   #9
Oldbluoval
Oldbluoval's Avatar
If the header is vibrating….the mirror will do the same. Maybe worse as it is extended and gets more leverage/wiggle room
Old 08-15-2021, 11:21 AM   #10
KenBolton
Aren’t they suppose to vibrate????????
KenBolton is offline   Reply With Quote
Old 08-15-2021, 11:54 AM   #11
abachman3
abachman3's Avatar
Vibrating tells you that the motor is still running!
abachman3 is offline   Reply With Quote
Old 08-15-2021, 11:54 AM   #12
MikeK
MikeK's Avatar
The mirror vibration problem also often occurs on modern cars when you replace a broken side mirror glass with a cheapo non-factory piece. WHY??-
Every object has what's called a 'period of motion'. That's basically the frequency at which it will swing/vibrate when given one impulse of inertial movement. Mounted automobile mirrors are like clock pendulums. Change either the distribution of mass or the length of the arm and the period of motion changes. When the vibration of the vehicle approaches any mathematical relation to that period of motion the mirror will go into a harmonic and vibrate strongly.
Modern cars that suffer after a non-factory cheapo mirror replacement have less mass and incorrect mass distribution. The fix there is to epoxy some weights to the back side edges of the glass.
To fix the mirror on a Model A, in addition to isolation mounting as suggested above, you need to increase the mass which will lower the frequency of motion. I have tamed several add-on exterior mirrors by opening or drilling the external SS case and filling the void with #7 lead shot.
MikeK is offline   Reply With Quote
Old 08-15-2021, 11:59 AM   #13
J Franklin
J Franklin's Avatar
Counterbalances on the crank and a full balance of the reciprocating parts will help. Maybe a harmonic balancer up front would be a good touch. Back in the day there was no problem with a dancing mirror because the model A was so far ahead of all the other cars on the road!
Old 08-15-2021, 01:56 PM   #14
ronn
except the 6 cylinder chevys!!!!!!!!!!!!!!!!!
Chevy outsold them by a ton.
Old 08-15-2021, 01:57 PM   #15
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Might try a rubber faucet washer.
Ivan in southeast va. is offline   Reply With Quote
