04-09-2016, 01:48 AM | #21 | |
Re: '35 3W glass channel placement?
I put the regulator thru the big hole in the door, cranked it full up, dropped it to the bottom of the door, slid the window in thru the top and rotated it into the fuzzy glass runs, lowered it until the channel was by the big hole, engaged the regulator arms into the channel, raised the whole works up until the drive shank fit thru its hole, cranked it a little until all the screws could be installed, rolled it down and installed the roller on the channel, rolled it back up, and checked the vent operation. Your later regulators are a longer; but I don't see where that would make a difference. |
04-11-2016, 11:25 AM | #22 | ||
Thanks for the pic Randy, I dont think ive ever seen the other type before. I wish they would have moved the window crank instead so i dont bang my knee on it.
Rich, I finally found a pic of what im missing but i guess its nothing special, thanks for the help. Quote:
Throttle Benders Est. 1949
04-11-2016, 06:22 PM | #23 | |
I just took a "slice" of a 3/8" bolt, drilled and tapped it for a 10-32 screw, worked fine. |
04-13-2016, 01:27 PM | #24 |
Thanks i'll probably have to make something, neither one of my doors had any rollers, maybe they've just been missing all a long?
