Old 05-24-2024, 01:01 PM   #1
Ggmac
Default Anyone need a 33-34 front shock for parts
I found a shock which may be a 1933 or 34 front . No arm and probably just parts . Free just pay shipping or pickup . I can email pictures.
If inappropriate here please delete.
Gary
Ggmac is offline   Reply With Quote
Old 05-24-2024, 03:05 PM   #2
DavidG
DavidG's Avatar
Default Re: Anyone need a 33-34 front shock for parts
No shock absorber serves as a front shock on both '33 and '34 Fords. The former fits inside the frame and the latter fits 9n the outside of the frame.
DavidG is online now   Reply With Quote
Old 05-24-2024, 03:16 PM   #3
Ggmac
Thanks David , I edited my post . Do you have a picture of the 33 front ? It has two spots where the fill hole could go but only one is drilled . I’m going off a internet picture of ford shocks and I’m too challenged on posting pictures here . I can e- mail the reference picture I’m talking about . Or I can go and take a picture of the shock .
Old 05-24-2024, 04:11 PM   #4
DavidG
DavidG's Avatar
Email is fine at [email protected].
Old 05-24-2024, 06:27 PM   #5
Ggmac
Thanks David . Pictures sent . I hope . After thinking about it and looking at the shock , it must be an inside mount .
Old 05-24-2024, 11:21 PM   #6
Newc
Newc's Avatar
Found some '33 types that are a bit shorter than 34-36 rear types? Spec's of '33 fronts? Newc
Old 05-25-2024, 04:58 AM   #7
Ggmac
Newc , I’ll measure before I ship it off .
The shock is gone .
Old 05-25-2024, 07:08 AM   #8
Terry,OH
Terry,OH's Avatar
Ggmac: Ford did not use the same shock from 34-36 on the rears. They are interchangeable.
Old 05-25-2024, 08:22 AM   #9
DavidG
DavidG's Avatar
The '35-'36 rear shocks have a greater capacity and are therefore have larger housings compared to the '34 rears. As Terry points out, they are functionally interchangeable.
What distinguishes the '33 shocks from the '34 rears are the filler plugs. The '33 plugs are about an inch long, have a hex head, and are at an angle to the shock body. The '34 filler plugs are about a 1/2" long, have a square head, and fit perpendicular to the shock body.
Old 05-25-2024, 12:41 PM   #10
Ggmac
Terry , not sure what you’re referring to .
David identified the one I’m referring to as a post production 33 front , 34 rear .
Gary
