04-19-2016, 09:24 PM | #1 |
Fuel pump
Can I run a electric fuel pump through the stock fuel pump on a 59ab? Do i have to modify the stock pump?
04-19-2016, 09:56 PM | #2 |
Re: Fuel pump
Yes and yes & no. Depends on what you are wanting to do, just use the elec pump part time or run on the elec all the time. If all the time you are better off modifing the original pump to prevent a diaphragm leak from filling the engine with fuel. Several Barn members have made this mod.
04-19-2016, 11:19 PM | #3 |
Re: Fuel pump
What do I need to do to modify the stock pump?
04-20-2016, 05:10 AM | #4 |
Re: Fuel pump
You can remove it / block it off or read Vic's thread "what I did on my lunch hour" (on barn) he goes into detail on exactly what you need to do, to make it a pass through
04-20-2016, 06:12 AM | #5 |
Re: Fuel pump
Yep, Vic has become the "go to guy" for details on how to modify a mechanical fuel pump in order to run an electric FP full time, and have the gas go through the mechanical pump without the fear of filling the crank case with fuel.
04-20-2016, 06:27 AM | #6 |
Re: Fuel pump
04-21-2016, 01:36 PM | #7 |
Re: Fuel pump
Just curious - Vic why do you leave the push rod in the block? Is it a chore to remove, or not a good idea to do so?
04-21-2016, 01:50 PM | #8 |
Re: Fuel pump
So he can convert it back to a mechanical pump any time he wants without having to pull the intake manifold. And there is the added benefit of it partially plugging the oiling hole in the bushing.
04-21-2016, 04:23 PM | #9 |
Re: Fuel pump
JSeery is correct. I always carry a 'known to be good' OEM fuel pump with me just incase the electric pump fails.
04-21-2016, 05:35 PM | #10 | |
Re: Fuel pump
John |
04-21-2016, 05:47 PM | #11 |
Re: Fuel pump
This is a little off topic but I don't think my reproduction fuel pump is pumping enough fuel to my 1941 engine. Are there good ones and not so good ones? If so, which are good?
I put a clear fuel filter in the line so I can see the fuel flow which is why I don't think it works well. Thanks. |
04-21-2016, 06:00 PM | #12 |
Re: Fuel pump
I am running a stock fuel pump with an Airtex 12V electric pump in the fuel line near the gas tank. I switch the electric pump on to fill the carbs and turn it off when the engine starts. If I leave it on it will force gas past the gasket on the mechanical pump and get gas all over. The mechanical will pull gas through the electric pump just fine. Previously I had a different electric pump and the engine would lean out after 2000 RPM,
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
04-21-2016, 06:00 PM | #13 |
Re: Fuel pump
John, my reasoning is simple, I've had too many manual fuel pumps fail, while out on the road. I was simply tired of making multiple road side repairs only to find that the replacement manual fuel pumps (that had all been rebuilt by an individual from the North East) were no good! One pump lasted less than 1oo yards on the highway . In my opinion (based on my experience) the electric pumps provide a number of benefits over the mechanical pumps, one that has proven to be especially helpful is the constant fuel pressure provided by the electric pump. Constant fuel pressure at speed provides instant throttle response and at idle (like when you are sitting at one of the seemingly never ending traffic lights) the pressure delivers liquid fuel to the carb, not giving it a chance to vaporize... that has vanquished Vapor Lock in my Flatheads. As I mentioned, I keep a 'known to be good' OEM pump with me incase of a failure of the electric fuel pump, not Vapor Lock. I should mention that in over fifteen years of driving Flatheads with electric fuel pumps, I have not had any reasons to go back to the manual pumps.
I like to convert the manual pumps to 'pass through' pumps just to keep things looking 'stock' under the hood.
04-22-2016, 07:47 AM | #14 |
Re: Fuel pump
If you are running a low pressure ele pump there should be no problem since the gas will just pass thru the fuel pump valves. Just pick up a stock pump and blow thru it from the "in" side. I have several vehicles set up with a elec pump for emergency and they work fine. Only time gas would get in the crankcase would be if the diaphragm were ruptured on a mech. pump.
04-22-2016, 08:49 AM | #15 | |
Re: Fuel pump
01-14-2018, 09:35 PM | #16 |
Re: Fuel pump
01-15-2018, 07:04 AM | #17 |
Re: Fuel pump
Search Vic’s thread on this forum - the title is “what I did on my Lunch hour”
He goes into great detail on how it’s done. The post goes into many other subjects so be patient in your search for the article
Thanks Andy 1952 F1 |
01-15-2018, 08:47 AM | #18 |
Re: Fuel pump
It was brought to my attention that, in an earlier post on this thread, I mentioned that I had a number of rebuilt fuel pumps go bad in short order. Those fuel pumps were rebuilt by someone in Connecticut (the North East), whose name I will not mention. There is another Barner in New York (also the North East) who's name I will mention. Charlie NY has rebuilt Carburetors for me that are outstanding. He also rebuilds OEM fuel pumps that I'm sure are every bit as reliable as his carbs however, to my knowledge, I have never used one of his fuel pumps. Sorry for any confussion my previous post might have caused.
01-15-2018, 10:22 AM | #19 |
Re: Fuel pump
01-15-2018, 10:39 AM | #20 |
Re: Fuel pump
Even though Vic is an extremely fit man (been on cover of GQ mag laying on hot Florida pavement and sliding under his vechicles may be a bit tight. Not to mention the need for hose clamps and additional tools to remount new pump to frame.
Two bolts to replace fuel pump
