11-04-2011, 07:34 AM | #1 |
1928 roadster trunk to rumble conversion
Good morning,
A friend dropped off a 1928 roadster with a trunk, And wants me to convert it over to a rumble seat. My question is it very difficult to do ? Can I weld up the trunk Lid and drill another hole for a rumble handle ? Or should I get a new deck lid ? Thanks, Mike |
11-04-2011, 08:30 AM | #2 |
Re: 1928 roadster trunk to rumble conversion
The deck lid should be the same but there are several inner trunk pieces involved to convert it properly. I can provide all the proper panels. Looks like there is a curved inner panel, rumble seat platform, rumble seat floor, and a seat riser, hinge braces, and front braces. 800-543-5035
11-04-2011, 10:06 AM | #3 |
For a bit of reference go to my page on rumble lids.
Assuming the lid is a 28-29 lid then you will have to move the lower latch to the upper position. The lower hole can be welded up or some cover it with a button. Positioning the latch is not complex. You need to locate the center line for the hole. The actual position of the square hole and the distance from the top edge are found using the latch itself. The latch must be tight against the outer lid metal so you do not get a depression when you tighten down the rumble handle. If the lid is an original lid then you REALLY want original rumble hinges. They just lay in and fit nicely. Repro lids on an original lid are just asking for trouble. A repro lid is just not right and you will have lots of fun making it right. You will need to solidly mount the braces under the rumble seat riser. They will be taking the force of a lid being opened. They were spot welded on all rumble seat cars. There repro curved inner panel will not have the screw holes in the correct position. You will also have fun setting up the rumble lid stops with repro parts. Just take your time seeing how the parts need to fit and function. Note that the curved inner panel has a spare tire brace rivet to it with a rectangular hole. This is needed for a rear spare. |
11-04-2011, 10:12 AM | #4 |
There seem to be more people wanting to convert from rumble to trunk these days than the other way around. Find one of them and trade parts.
Joe
1929 Tudor since 1962 Feather River A's |
11-04-2011, 11:01 AM | #5 |
If your friend insists on a rumble seat, then I'd follow JoeWay's advice.
But first I'd put the project on hold and ask your friend to think long and hard about doing the change. Many rumble seat owner's are now longing for a trunk, as they are much more practical. Several rumble seat owner's here have mantioned that they won't even allow anyone to ride in the rear because of the added danger. Hopefully your friend will reconsider and keep the trunk. It's kind of like me living in Minnesota and owning a 28 Phaeton. Sure it's a "cool" car, but most of the time it's too cool. My 29 Tudor is really a lot more practical. Last edited by Tom Wesenberg; 11-05-2011 at 12:06 AM. |
11-04-2011, 01:01 PM | #6 |
The middle daughter, who demanded a ride in early March, pronounced the experience, "True brain freeze." It was a bit cool. That said, I admit that when we drove to Amana for the Hawk A's shindig I took the cushions out to make more room for "necessities." It also provided a great place to stow the car cover without taking time to mash it into its bag. I still like rumble seats. And aahooga horns. |
11-04-2011, 03:22 PM | #7 |
I converted my roadster to a rumble from a trunk. As far as safety goes, it really isn't that much more dangerous than any other Model A really. Look where the passengers sit in a sedan, right in the rear of the car. With the exception of not being ejected as easily, as the rumble, or any open car for that matter. They're all in reality, rolling metal death traps. The only safety in these cars is the "safety glass" windshield. I drive mine with that knowledge and do my best to avoid being victim of the other guy, as well as myself.
11-04-2011, 05:05 PM | #8 |
When I restored my 29 rdstr. a few yrs back I had the parts to go either way. I chose to go with a trunk & very happy I did. We also have a 68C Cabby that we have taken on several long trips. The rumble seat cushions are out 95% of the time. Even with the cushions out it's much harder to get stuff in & out. The rdstr. with the trunk lid has much easier access especially up closer to the front seat.
11-04-2011, 05:15 PM | #9 |
I converted the trunk in my '32 roadster to a rumble seat when I restored it in the seventies. If I had it to do over again, I would keep the trunk.
Charlie Stephens |
11-04-2011, 09:09 PM | #10 |
My Coupe was made with a trunk and I'm glad. It's nice to have all the storage room. That said, everytime someone looks at my car, they ask me if it has a rumble seat.
Tim |
11-04-2011, 11:46 PM | #11 |
The coupe I am restoring had a trunk originally. I started the conversion to a rumble seat. However, I recently changed my mind and am going back to the trunk set-up. Safety and storage are the determining factors.
11-05-2011, 09:49 AM | #12 | |
11-05-2011, 10:08 AM | #13 |
I converted to a rumble on my roadster 30 years ago, it's neat, but when I redo the car, I am putting the trunk back....
