06-20-2019, 11:01 AM | #21 |
Re: 39 Coupe Broken Axle Removal.
So just checking again and it would appear the inner axle seals which sit in behind the bearings are not fitted? The bearing is located in a recess at bell but the inner seal when fitted is located how? Does it just sit on the axle as there is no shoulder to locate?
Have read the Ford Bulletin and past posts and understand sharp edge to diff to retain oil. Phil NZ |
06-21-2019, 03:37 PM | #22 |
Best part of using a port-a-power is you can position yourself out of ‘the line of fire’ while spreading the spring.
06-21-2019, 03:41 PM | #23 |
Or you can have a cold one while you instruct your wife how to do it.
Alan |
