05-16-2010, 02:08 PM | #1 |
Info on diaphragm clutch for Model A
I have had some email inquiries about the 10" diaphragm clutches that John Lavoy wrote about in the Spring 2010 Model A Times.
I've put up a web page with more information. http://originalmodelaparts.com/DiaphragmClutch.htm Joe
1929 Tudor since 1962 Feather River A's |
05-16-2010, 02:37 PM | #2 |
Re: Info on diaphragm clutch for Model A
What will they think of next Joe!
A diaphragm for our lady. Does that mean no repoduction? Pluck |
05-17-2010, 09:27 AM | #3 |
Joe, Thanks for the excellent follow-up details!
You have noted the Seco fingers to be at a steeper angle than the Luk. This must have some effect on the change of pedal pressure through its travel. I have two questions: 1) How does the pedal pressure of the Seco and Lux compare at two points- the friction point and fully depressed? 2) After cutting and installed with a new disc, what is the distance (height) of the fingers from the flywheel surface? Is it the same for the Seco and Luk? |
05-17-2010, 10:35 AM | #4 | |
When I finish the pressure gauge I'll make the rounds of club members' cars and get info on stock, V-8, and diaphragm clutches, and add that to the web page. Pedal pressures on stock and V-8 plates vary widely as has been discussed here in the past, depending on what springs were used in manufacture or rebuilding, but the range of data points will be interesting. Maybe I'll see if Marco would be willing to check the pressures on his NOS and low-miles original clutches, which he says are quite easy to operate. Height of the fingers is another good question. I'll have to round up some more covers to get answers as I don't think I can get a measurement in the car. Right now all the ones I've worked on are installed. All I can say about the height right now is that the clutch adjustments required only a touch-up on two of the cars. Not sure about the other two. I'll post again when I have more information to offer. Joe
02-01-2012, 02:51 AM | #5 |
Hi Joe - I've had little luck searching for the clutch numbers here in the UK - don't suppose you know the original fitment?
02-01-2012, 11:59 AM | #6 |
02-01-2012, 09:15 PM | #7 |
As part of my F150 OD install, I used a diaphragm pressure plate out of a 86 Ford Thunderbird 2.3 liter 4 cylinder turbo. It is attached to a lightened (34lbs) Model A flywheel.
AL in NY |
02-01-2012, 10:48 PM | #8 | |
I'm now working on a flywheel that I will drill for a Chevy S-10 clutch cover--SACHS BBC1904--that is supposed to work with an A clutch disc. I'll be adding info on that to my web page when I get it done. Joe
02-02-2012, 02:44 AM | #9 |
Al - That looks exactly like the Ford Sierra clutch cover I had out at our local parts centre - but I don't think the hole centre is large enough for a Model A box?
02-02-2012, 09:33 AM | #10 |
Dick Spadaro has started a clutch p/p thread on the EV8 site, addressing some problems with the EV8 set ups. Might make informative reading .
Paul in CT |
02-02-2012, 10:26 AM | #11 |
Ron Kelly the engine builder in texas has been using a diaphragm clutch in model As for years. cant find the part # he gave me .
