08-26-2019, 01:59 PM | #1 |
Unibody car on jack stands.
Haven't had had an old car with unibody construction til the '65 T Bird I bought last year. I need to get underneath to access the trans vacuum mo. valve. I presume the jack stands will go on the big seam weld running the wheel base along the outer edge of the underside, but I thought I'd check with you guys first.
Thanks. |
08-26-2019, 06:24 PM | #2 |
Re: Unibody car on jack stands.
On my 08 mustang you use the jack stands on the pinch weld along the outer edge.
08-27-2019, 01:40 AM | #3 |
if in doubt, jack up the rear axle and front suspension. If I'm going to have my 56 up for long that's what I do... closest to how it sits on it wheels.
08-27-2019, 03:49 AM | #4 | |
08-27-2019, 05:29 AM | #5 | |
Front - placing the jack under the engine cross-member, or @ control arm mount(s) and raise and place jack-stands. You will notice short rails after the engine cradle. This is where you want the stands. Rear- either by raising by the center section of the rear and placing the stands under the axle tubes or @ the front spring perch mounts/short frame rail extensions. Even though there is a special jack pad to raise a car by the outer rocker panel seam, I would advise against it. Doesn't take much here to damage it. There are also pads available for the stands that will cushion the load of the metal (sheet) to the stand.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
08-27-2019, 05:52 PM | #6 | |
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
08-28-2019, 07:53 AM | #7 |
Always get the shop manual for the car from Helm Inc., best money you will ever spend on your car!
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
08-28-2019, 11:14 AM | #8 |
Thanks guys. I do have the shop manual, but can't find anything in it about leaving the car on jack stands. Don't know how long I'll have it on stands, but I'm guessing less than a day.
