06-09-2017, 07:13 PM | #1 |
Changing out a 34 Ford car Trans for a 36 Ford car trans
I have a chance to pick up a good 36 Ford trans , can I replace my 34 Ford car trans with this one, the 36 , what modifications need to be done ? can I use the 34 Tower on the 36 Trans ..Thanks
06-09-2017, 09:01 PM | #2 |
Re: Changing out a 34 Ford car Trans for a 36 Ford car trans
Sounds good to me!
Don't never get rid of nuthin! |
06-10-2017, 04:24 AM | #3 |
I believe it is an easy swap BUT I am sure you will have to use the 36 Shift lever as the tower is straight up vs slanted and the part of it that works the forks is longer on the 36. Hope this helps. kerk
06-10-2017, 05:09 AM | #4 |
Let's assume that the 36 transmission is in good working condition. The 36 would have all-helical gears, but otherwise, it's got the same synchronizer. You'll have to stay with the 36 tower and lever......unless you're willing to pull the thing apart and replace the low/reverse slider gear with one that works with the 36 forks.
Up front, you'll have to swap the clutch release arm from your 34 onto the 36 clutch shaft. At the back is a group of parts that make up the rear support. You need to install the 34 assembly onto the 36 transmission. The 36 shift lever is a tad longer with a curve to the rear. It might hit the seat cushion on the 1st and 3rd shifting positions.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
06-11-2017, 06:35 PM | #5 |
Thanks Guys , Mac VP, thank you for the detailed difference between the 34 & 36 transmissions , I may rebuild my 34 from scratch and put the syncro in , same as the 39 ford , thanks ..RS
06-12-2017, 10:48 AM | #6 |
06-12-2017, 11:19 AM | #7 |
It's not just a claim. It has been done by someone who posts on this forum and works well on two of his early Ford V8's that are driven many miles each year. I can't disclose the individual who has done this because he may want to make these for sale at some point. He also made a set of these forks for me, and if I ever get off my duff, they will get installed in one of my '35 coupes when I replace the original '35 gears with '46-'48 gears.
06-12-2017, 11:08 AM | #8 |
The '36 tower is straight up and looks like a '39. The '36 tower will accept most any '36 to '39 pass. car and '36 to early 50's pu truck floor shift lever. If you go with a pu shift lever, it looks like a '34 and may work better with '34 seats, although I'm not sure if it would hit the dash. Any of these levers can be reformed to fit your needs.
06-12-2017, 02:26 PM | #9 |
I just wonder how the increased amount of throw was compensated for since the shift lever is shorter. The later synchro has to move a bit farther each way to work. A person like me can't say it's gospel to others without seeing it work for themselves. This is the only reason I used the term "claim" with respect to this alteration. If an altered set up will work then I think that's great. There may be more than a few folks that would like to go that route at some point. It would certainly be a nice improvement over stock for the 1932 through 1935 passenger cars and commercials.
