09-16-2019, 09:02 PM | #1 |
Resistor for 12v Skip rewind coil
I'm looking to have Skip rewind some '42 to '48 coils for 12 volts, what
value resistor should be used ? Thanks, Charlie ny |
09-16-2019, 10:04 PM | #2 |
Re: Resistor for 12v Skip rewind coil
Charlie, maybe Bubba will chime in but skips coils seem to be .8-1.0 ohms primary. 12v likes 2.8-3.3 ohms so..... In my opinion a 1.8-2.2ohm resistor would be perfect or close to that
What I’ve used is a Moroso part# 72390 1.8 ohm although I would prefer a 2.0 ohm for extended ignition point life Last edited by 35fordtn; 09-16-2019 at 10:10 PM. |
09-17-2019, 05:43 AM | #3 |
Charlie,
I just had this done. Let me see if I can find the paperwork. Skip lists it. |
09-17-2019, 06:41 AM | #4 |
I just looked over the paperwork. It just says must use a 12V resistor with this coil. Sorry I couldn't be of more help.
09-17-2019, 12:37 PM | #5 |
The coil in question is Skip's design so I can only assume that he is referring to the 1.3 to 1.5 ohm type. |
