02-14-2014, 06:48 PM | #1 |
Question about '34 Seat??
I have a '34 five window coupe.
I have a new BOTTOM seat spring that I will be putting new upholstery on. I assume the seat spring assembly should be fastened to some sort of wood frame work or a sheet of plywood. Can anyone show me what this wood frame looks like AND what is the corret thickness of it? Thanks much, Jim Boehmke |
02-14-2014, 07:43 PM | #2 |
Re: Question about '34 Seat??
Go look at fordwoodart.com they have a picture of the wood piece.
02-14-2014, 09:29 PM | #3 |
thank uptown, but I did not know what to look up on that website.
JIm |
02-15-2014, 12:05 AM | #4 |
Oh go to the online store and select 1934 and click search. Scroll through the pages
02-15-2014, 09:24 AM | #5 |
This photo is 35 but the 34 appears to be nearly the same construction but different size. From memory the wood is 3/4" thick
02-15-2014, 09:34 AM | #6 |
02-15-2014, 10:15 AM | #7 |
Terry and Uptown, many thanks for your help on the seat. I'll go into construction mode tomorrow. Ford Barn to the rescue again!
Jim |
02-15-2014, 12:30 PM | #8 |
Here are two pictures of my '33 5 window seat. Obviously I've modified the seat, but the metal bottom is original as is the wooden frame for the seat bottom. I did add the center piece of oak in the seat bottom as I'm using foam for the seat support. If you need any dimensions etc., just let me know. BillIMG_8605.jpg
IMG_8606.jpg |
02-15-2014, 03:27 PM | #9 |
many thanks Bill, for the added photos. I have the big picture now and can proceed.
Jim |
