11-14-2014, 06:49 PM | #21 | |
Re: 1933 can't start after recent restart
I recently had my computer crash and I am using another computer.... I will check under the fuse question...I think that is where you posted it. Thanks... It was great...The photo was exactly like my car. Last edited by FrankWest; 11-14-2014 at 07:02 PM. |
11-14-2014, 07:01 PM | #22 | |
11-14-2014, 07:03 PM | #23 |
11-28-2014, 10:42 AM | #24 |
Still no spark
High tension wire badly crystallized and fractured Replaced No spark New Development Noticed badly frayed wires connected to battery junction (-) wire under steering box in engine compartment. One wire comes from inside, Maybe ignition switch?) and another one to lights May have eventually shorted as car was running? I need some help in a picture of this connection under steering box. I need to replace these exposed wires, but need to know what they are? Any help will be appreciated. |
11-28-2014, 10:59 AM | #25 |
The wires under the sterering box are for your lights and horn.
There is a single glass fuse on the backside of the dash, drivers side. Check it. It it is broke the engine will crank but no spark. Your problem is more then likley extremly simple. If the fuse is good, get a test light and with the ignition "on", touch the point plate inside the distributor. If it lights up that tells you there is power to the distributor (eliminating the electrical on the switch inside the car) If it does not light up, trace back and see where the test light lights up, and you will find your problem.
Thee Inland Emperors |
11-28-2014, 10:59 AM | #26 |
Mart. |
11-28-2014, 12:13 PM | #27 | |
Is that a 20 AMP fuse? |
11-28-2014, 12:16 PM | #28 |
Yes, I belive so...but it should say on the fuse
11-28-2014, 06:09 PM | #29 |
Unless it has been modified, the fuse is for the lighting circuit only. The ignition wiring was not routed through the fuse originally.
11-28-2014, 06:19 PM | #30 | |
This diagram is from the ford 1933/1934 restoration manual |
11-28-2014, 06:45 PM | #31 |
Frank, follow the "Y" wire. The starter switch is fed from the battery, the yellow "Y" wire goes from the starter switch to the ammeter. Then the "YB" wire goes to the ignition switch. The ignition is not fed through the fuse.
All the lights are fed from the "YB" wire from the other side of the fuse. The diagram is very simple, it should be easy to follow. I find it best to just concentrate on one wire or circuit at a time. Mart. |
11-28-2014, 07:00 PM | #32 |
Mart,
Well said (follow one wire at a time). |
11-28-2014, 07:44 PM | #33 |
As stated above, the voltage coming from the battery hits one side of the fuse block. The other side of the fuse block is the light circuit.
11-28-2014, 07:48 PM | #34 | |
Could the generator cutoff be shorted resulting in a blown fuse? |
11-28-2014, 07:54 PM | #35 |
Post a picture of your fuse block. Has any of the wiring been changed or moved around since you have been troubleshooting this problem?
11-28-2014, 08:15 PM | #36 | |
THose wires under the steering block were badly frayed with exposed wires and bird caged vould these have shored out to the steering frame that may be positive right because of the positive battery terminal connected to the frame, |
11-28-2014, 08:21 PM | #37 |
fuse box and under dash wiring
11-28-2014, 08:32 PM | #38 |
If you have frayed wires, they are the #1 suspect in determining why you are blowing fuses. Nearly every metal part on your car acts as a ground and any bare wire in the lighting system touching a nearby metal part will blow the fuse. At least you know that the fuse-blowing problem is confined to the lighting electrical circuit and not caused elsewhere in the electrical system.
11-28-2014, 08:49 PM | #39 |
Do you know how to use a volt ohms meter and a test light. They will really help.
11-28-2014, 08:52 PM | #40 | |
