Old 08-15-2013, 02:22 PM   #1
barnfind08
Default 1934 door check strap how?
Installing my 34 3W door check strap(nos) but the 3W has wood in the "B" pillar. I looked at my other 34's and they all have 2 screw holes for small bolts to hold it to metal "B" pillars. What now? Any help from someone with a 3W that can take a peek? Thanks in advance Fred
barnfind08 is offline   Reply With Quote
Old 08-15-2013, 03:03 PM   #2
Barn Junk
Barn Junk's Avatar
Default Re: 1934 door check strap how?
Seems like a 3-W uses the same metal clamp that bites into the strap but uses long wood screws to attach deep into the wood door post. Been a while since I did that.
Barn Junk is offline   Reply With Quote
Old 08-15-2013, 04:38 PM   #3
Lawrie
Lawrie's Avatar
My 34 3w has the end of the strap held to the wood insert in the pillar by a little u shaped plate with claw edges,and two long wood screws,
Lawrie
Old 08-15-2013, 08:02 PM   #4
Barn Junk
Barn Junk's Avatar
Lawrie
Yes, that's what I remember. The U-plate has some teeth on it that tighten down into the strap when you determine the stop point.
Old 08-15-2013, 08:07 PM   #5
barnfind08
I thought there was something missing. I have a few of those clamps with the teeth but I thought ford would be more ingenious than just a couple of screws. Thanks guys.
Old 08-16-2013, 08:36 AM   #6
Steve Staysko
Steve Staysko's Avatar
It looks like this and you can buy them from Vintique USA.
File Type: jpg $(KGrHqEOKicE6YYb1mmYBOuueVpqCw~~60_12.JPG (24.4 KB, 16 views)
File Type: jpg $(KGrHqIOKjIE6RdkOJYkBOuueVBi5!~~60_12.JPG (25.0 KB, 12 views)
Steve Staysko is offline   Reply With Quote
