Old 05-02-2021, 07:28 PM   #1
47Merc
Default 1940 Steering box
When replacing the roller wheel in a 1940 Ford steering box how do you secure the wheel shaft in position to stop it moving and coming out of the roller shaft?
Thanks
47Merc is offline   Reply With Quote
Old 05-03-2021, 01:13 AM   #2
47Merc
Default Re: 1940 Steering box
Maybe I should re phrase that and ask How do you stop the pin coming out of the cross shaft? I have looked on Van Pelts site and others regarding rebuilding a steering box but have not found anything regarding this matter. Should I try to pin it or weld it or ?
Old 05-03-2021, 02:05 AM   #3
FlatheadEric
FlatheadEric's Avatar
I saw a 40 box recently where a washer had been slipped on to the end of the shaft and welded in place. The weld was crap and had broken allowing the shaft to slide out of the wheel and jamb against the steering box housing. OK if you want to just turn in one direction all of the time. Nasty if you are travelling at speed when the weld lets go.
I think the person that welded the washer to the shaft did not get enough heat into the shaft to stick the washer properly to the shaft.
Probably a good method if the thin washer is welded to the thick shaft correctly.
FlatheadEric is offline   Reply With Quote
Old 05-03-2021, 07:08 AM   #4
Terry,OH
Terry,OH's Avatar
Good spot welds (not tack welds) in several positions, usually no need for a washer since the pin is not supposed to turn.
Old 05-03-2021, 09:46 PM   #5
47Merc
Quote. "I saw a 40 box recently where a washer had been slipped on to the end of the shaft and welded in place. The weld was crap and had broken allowing the shaft to slide out of the wheel and jamb against the steering box housing. OK if you want to just turn in one direction all of the time."
Exactly what happened in mine. It has chewed away the stiffener rib inside the box but fortunately hasn't jammed. It didn't have washers on it but the shaft appears to be hardened steel and the weld didn't stick to it. They must have been a press fit originally.
I'm thinking of center punching around the holes before the shaft goes in, putting loctite 406? on it and pressing the shaft in.
Old 05-19-2021, 06:20 PM   #6
47Merc
Further to the above post I have installed a new roller, worm, bearings, bush etc and have adjusted the free play in accordance with the instructions laid out on Van Pelts site. With it clamped in the vice, I have the adjustment so there is virtually no free play between the steering shaft and the pitman arm in the straight ahead position and only a slight drag is felt when moved but as it is turned in either direction the free play on the pitman arm becomes quite loose until at full lock there would be at least 1/4 inch of movement.
Is this normal or do you think the repo worm is not manufactured correctly to compensate for the movement. Or is it me?
Old 05-20-2021, 11:34 AM   #7
rustythumb
that sounds normal.
rustythumb is offline   Reply With Quote
Old 05-20-2021, 06:46 PM   #8
47Merc
Originally Posted by rustythumb View Post
that sounds normal.
Thanks. I'll put it back in the car and try it.
Old 05-20-2021, 07:03 PM   #9
Pete
Pete's Avatar
That is a built in problem with that type of steering.
