04-03-2011, 08:24 PM | #1 |
automatic for an A
I have a friend who had lost a leg and other complications, makes you count your blessings. He is doing great with a remarkable attitude so I feel he will do well! It just got me to thinking, something I often do after the fact, of how it would effect my lifestyle. Mentioned it to the misses and she says I don't have a lifestyle! Bless her black little heart, back to my thoughts, I would certainly miss my A's and felt that with hand throttle and one leg I could do OK... With all this blabbering [no I don't drink] I don't think I have ever seen an automatic transmisson swap article! Plenty of overdrives etc but I feel in my gut that you should be able to put one of those transmissions from a small four cylinder car. Of course most are electronicaly controlled would probably need 12 volts etc. Has there been threads or articles on this and of course the mechinics of connecting the diveshaft to the trany and then the trany to the engine.. has any of you brave souls tried this and if so let us know. For now I will just think about this and research it,than add it to my bucket list [I keep adding to it so I don,t die] . Now I don't have the time but I got that spare engine and I know of a chassis not doing nuting maybeeeee!
04-03-2011, 08:45 PM | #2 |
Re: automatic for an A
Art Moore FAST member in Southern California uses Chrysler automatic in his A's as he does not have use of his legs. Jim Brierly who post here often can put you in touch.
Frank |
04-03-2011, 09:00 PM | #3 |
04-03-2011, 10:49 PM | #4 |
Bert's in Denver has a complete Chrysler automatic kit.
Steve and crew have installed at least one that I have heard about. www.Modelastore.com 1-800-321-1931 Store open Tues- Fri 0900-1600 MST Sat 0800-1200 |
04-03-2011, 08:57 PM | #5 |
Yes, Automatics can be very sussecfully be adapted to the Model A.
Art Moore, in Upland, Ca. lost the use of both legs has an automatic and hand controls in his Model A. He goes everywhere in it. I think he was also involved with making the necessary adaptors and doing the research to determine what automatic works best etc. As I understand it, this is a very successful conversion. I do not have his contact information but if you are interested in talking to Art, send me a PM and I will get it for you. Chris |
04-03-2011, 11:01 PM | #6 | ||
Adapter kit From the site; Quote:
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 04-03-2011 at 11:08 PM. |
04-04-2011, 10:43 AM | #7 | |
If anyone tries the THM200 conversion be aware that the 1979 version was a disaster. You might want to investigate this before using the early THM200s. I am not sure when the lockout 200-C or 200-4R models came out or if they were any more reliable.
The company I worked for ordered about 1000 or more '79 Chevys for company cars. I ordered mine right away and got the THM350 and 267 V8. Then some beancounter changed the rules and the V8 and THM 350 could not be ordered. He said that the 200 or 231 V6 (which only came with the THM200 and no lockout converter) got 2 miles per gallon more! "WOOPTY DO"! Of the twenty or so V6 - THM200 cars here in the Denver office every one had the transmission rebuilt at least twice and some 3 or 4 times before they had 60,000 miles. The same thing happened all across the country. The THM 350s were bullet proof ... several went over 300,000 and one 500,000. One guy had a THM 350 fail right before 60,000 but he was running the car backwards and jamming it into drive while jumping on the gas pedal. After several tries it "just made a loud noise" as the driver told the boss and quit going forward. The company had it fixed and another guy bought it ... that is the one that went over 500,000. Quote:
04-04-2011, 07:59 AM | #8 |
I, also, and toying with the idea of an Automatic behind a Model A engine. My missus, Lillian, cant drive a car with one of those clutch thingeees in it. Dick Sparks, who lurks and post occassionally here has done it and it did not look complicated. He used a Ford C-3 or C-4 3 speed auto probably from the 60's or early 70's. It is a relitively small trans. Gonna git 'rount to it soon.
Now, lets see how this stirs up the purist. he-he. ken |
03-17-2017, 11:36 AM | #9 | |
Tell Lillian that she needs a note from her doctor before you will put an automatic transmission into the Model A. She should be able to learn to drive the clutch thingy in a couple of hours if she really wants to (maybe she would just rather you drive). It would take you hundreds of hours and thousands of dollars to install an automatic. Charlie Stephens |
03-17-2017, 06:08 PM | #10 |
We installed one of Art Moore's auto trans kits with the Chrysler 904 about 15 years ago, with a stock engine and 5.5 head. Works great!!! Car is still running strong.
The reason the 904 trans was chosen years ago for this conversion, is the starter is mounted to the transmission. Makes the conversion much easier. Car must be 12 volt (due to later starter), you must make a trans mount,and have hydraulic brakes (trans gets in the way of the stock cross shaft). I didn't think, prior to doing this, that a stock Model A had enough power to run this trans. I was wrong. It works perfectly. Call Art Moore, and have him set you up, but realize that you have to make the changes I listed above. If you need his phone #, call me. Steve @ Bert's modelastore.com |
03-17-2017, 10:25 PM | #11 | |
THANKS, for your input and clearing up some often stated misconceptions ,i.e.- not enough power to run an automatic, etc... |
04-04-2011, 08:20 AM | #12 |
I was a big fan of the TH200Cs bigger brother, the TH200-4R which has overdrive. I think its about the same as far as how much power it eats. A stock TH200-4R is relatively rock solid.
But as others have said, when you only have 40HP on a good day, losing 10-15 of it is a big deal. |
04-04-2011, 10:04 AM | #13 |
e-mail me at [email protected] for Art Moore's contact info. His A's have hydraulic brakes, I'm not sure if you could operate mechanicals with his hand controls, but if he still has use of one leg he may not need hand controls?
04-04-2011, 10:46 AM | #14 |
Benson,
The 1980s TH200-C wasn't that great either, this is why they stated "properly built". The TH200-4R's are usually rock solid in stock form. Another option is the TH700-R4 which is essentially a TH350 with overdrive. This is not a typo, one is -4R the other is -R4. |
04-04-2011, 11:32 AM | #15 | |
Mr tube,
Thanks for info ... My two TH350s went 175,000 (still good when I junked it) and 275,000. The 275K sedan did leak out torque converter because I put some of that leak "preventer" in ... it was supposed to "soften the seals". It did just that, the seals turned a pink color and leaked worse. Was drivable but if left over a couple of weeks without driving it, several quarts of the transmission fluid ran out on the ground. If run every week or so very little leaking. It did this for over 125,000 miles ... I just had to be sure it got driven regularly. Quote:
04-04-2011, 02:21 PM | #16 |
Jim Brierely can also put you in touch with a guy named Raul (I can't remember his last name) who has had excellent success with automatics in model A's.
04-04-2011, 03:56 PM | #17 |
I have a rebuilt torque flite 904 3 speed no overdrive from a 69 Dodge Dart slant six under the bench for my next project. This is the same trans as used by Art Moore.
04-05-2011, 02:28 AM | #18 | |
As someone mentioned above, and as you most likely know...more horsepower needed for auto powered with ford four banger! If anyone ever saw one of Art Moore' Model As with the automatics you'd know why his cars worked very well with automatic transmissions!! He is an amazing model a guy, which some here would call rodder! |
04-04-2011, 08:55 PM | #19 |
So why isn't anybody talking about putting a FORD automatic transmission INTO A FORD MODEL A instead of some of that off-brand crap?
03-16-2017, 11:18 PM | #20 |
C4 is a great auto for A or B banger.
It takes a lot of effort however. Two adapters and a custom flywheel. I run this setup in the FAST races with good results. |
