04-01-2011, 09:02 AM | #1 |
Flywheel for Balanced B crank
I have several flywheels to pick from...is there a difference between flywheels for use with Model A, Model B early, and Model B balanced? Dont want to use the wrong one with a factory balanced B crank. Thank you for any info.
04-01-2011, 09:09 PM | #2 |
Re: Flywheel for Balanced B crank
The green book shows B-6375 flywheel for 28-34 4cyl pass and truck
04-01-2011, 09:46 PM | #3 |
Pick the lightest one --the B was lighter than the A.
04-05-2011, 06:55 PM | #4 |
Re: Flywheel for Model B
The Model A flywheel may not even fit within the B flywheel housing. The B flywheel is listed as the service replacement for the slightly heavier A wheel and is still quite heavy. There was no change in the factory B flywheel when the counterweights were added. Unless you're flat broke, the lightened flywheel is worth the price to change. Good Luck: Fred A
04-05-2011, 10:16 PM | #5 |
