03-29-2022, 04:44 PM | #1 |
Dyna beads in wheels
Anyone had luck with the beads in you tires, I can not get my 35 to run smooth at cruising speed around 55 mph,have tried the modern balance ,have a bubble balancer I’ve tried,but nothing seems to help ,,,using the original rims ,,with radials which improved ride a whole lot,wheel bearings are all good and snug
DON P |
03-29-2022, 04:55 PM | #2 |
Re: Dyna beads in wheels
Lot of posts on the HAMB. Most are favorable. Here is a link for Dynabeads:
https://www.innovativebalancing.com/index.php
Making the simple complicated for over 30 years. |
03-29-2022, 05:10 PM | #3 |
Been using them for a number of years with similar set up.
was the only thing that corrected my issues.
03-29-2022, 06:28 PM | #4 | |
Check for out of round tire and run out on the rim. Put brand new Cooper tires on the newly restored '67 Mustang last summer, mounted and balanced at the local tire shop. Had a bad bounce at highway speed. Spun all the tires by hand with a block and bar close to the side wall--all good. Same on the face of the tread. Up on jack stands, spun up to highway speed, the tread on one tire swelled so easily visible with the naked eye. More things than just balance can cause tire shake. Yes, I got a new tire, no charge. |
03-29-2022, 06:58 PM | #5 |
was a sceptic till i tried them ;wont leave home without them but they wont cure an out of round or damaged wheel The beauty of them is you can rotate tires and no need to rebalance as they balance the entire rotating mass [wheel hub drum etc]
03-29-2022, 07:08 PM | #6 |
03-29-2022, 08:17 PM | #7 |
I swear by them on my 1 ton and 3/4 ton trucks. I have a terrible time getting beads through a valve stem though, I put them directly in a tubeless tire by breaking the bead, in a tube I need to use the finer powder size beads.
I overfilled a tire on purpose to see how it worked, that one needed a few revolutions at speed to smooth out, so I don't worry as much about the exact weight of beads now. |
03-29-2022, 09:46 PM | #8 |
out of round rim, bent rim, not enough shock
03-30-2022, 01:48 AM | #9 |
03-30-2022, 02:37 PM | #10 |
I have them in my 34, running 35 16inch wheels with tubes with radials. smooth as silk. The folks that sold me the beads did mention that they won't resolve side to side issues only rolling. So you may want to check the edge of your wheels when you spin them. Apparently thats why lead weights are both inside and outside. Ken
03-31-2022, 04:59 PM | #11 |
Have been reading several blogs on beads and some say they go thru a vibe ration till speed is reached going up and slowing down, some say theywork and others say they don’t ,,haven’t decided yet but might have to give it a try to find out for myself,
DON P |
03-31-2022, 05:07 PM | #12 |
Have fun installing them into an inner tube...
03-31-2022, 05:36 PM | #13 |
Run a drill (by hand) into the stem to help remove any possible blockage.
03-31-2022, 05:38 PM | #14 |
the experience with dyna beads may depend on how old the tires are and if youre running radials or new or dryed up bias ply. type and shape of lever vs tube shocks alignment. a few things to consider. just my two pennies. Tom.
03-31-2022, 05:50 PM | #15 |
Yup ,me too, Once & done. Won't leave home W/O em
03-31-2022, 07:11 PM | #16 |
I had an old timer in a local country garage tell that years prior an older old timer would come in for tires and pour sand in each tire before mounting them and never balanced his tires. That’s in rural Nova Scotia. I wonder what the history of beads/sand come from?
03-31-2022, 10:22 PM | #17 | |
04-01-2022, 02:15 AM | #18 |
I use them on my 35 coupe and they work perfectly!!
04-01-2022, 05:43 AM | #19 |
04-01-2022, 07:57 AM | #20 |
Needle off a WD-40 can would work also,have seen a ingraving tool to viberate stem works good
DON P |
